Old 10-05-2004, 09:25 AM
Oreif's Avatar
Oreif Oreif is offline
My car has just been converted fron a Chevy V-6 to a Chevy V-8. There isn't enough room to install a Pontiac 400 without extensive modification so I just bought a ZZ4 crate engine. (355hp/405 torque)
Hows it look?
It inside this:
Happiness isn't around the corner...
Happiness IS the corner.
1986 Fiero SE
Now ZZ4 Powered!
Oreif's Avatar
Hows it look?
It inside this:
1986 Fiero SE
Now ZZ4 Powered!
Old 10-05-2004, 01:18 PM
Trips4me's Avatar
Trips4me Trips4me is offline
Send a message via MSN to Trips4me
Nice job.. bet it's a bitch to change plugs though..
1965 GTO Hardtop - Fontaine Blue, Blue interior, 389 Tri-Power, 4 speed, 3.36 posi, Rally I's
Old 10-05-2004, 02:45 PM
78 GHOST 78 GHOST is offline
Very clean install!
If you ever get traction, you might need a wheelie bar.
____________________________________
"I work in high speed aluminum tubing."
Old 10-05-2004, 07:43 PM
Oreif's Avatar
Actually it is easier to change plugs than the V-6.
As for traction, Since the engine sits in front of the rear axles, (mid-engine design) The launch off the line is solid.
1986 Fiero SE
Now ZZ4 Powered!
Old 10-08-2004, 11:27 PM
bmpmdf bmpmdf is offline
So how high is the front wheels on launch? Or have you hooked up that hard yet? There is one in STL, MO. area that is wild to see at a stoplight front in the air.
Have A Great Day
Old 10-09-2004, 05:30 PM
Oreif's Avatar
The only way to get the front wheels off the ground is to mount the engine longitudal (turns the car into rear engine car) Or to have over 600hp. It is difficult when the engine is transverse mounted because the engine is forward of the rear axles (mid-engine design).
I am only pushing 355hp/405 torque, So the car just launches straight.
1986 Fiero SE
Now ZZ4 Powered!
Old 10-17-2004, 03:49 AM
BTW, nice ride.
Have A Great Day
Old 10-20-2004, 05:09 PM
almeyer's Avatar
almeyer almeyer is offline
Nicely done. How hard was the project? Did you have to fabricate a number of parts or were you able to buy most of what you needed?
Old 10-21-2004, 05:01 AM
Gary S. Gary S. is offline
It just doesn't look right,seeing the distributor out front!!
Old 10-21-2004, 07:49 AM
Donovan Donovan is offline
With aluminum heads and intake you didn't gain much weight compared to the 2.8?
Wish you were closer I'd love to ride shotgun through a few curves!
1968 Firebird Coupe - 3665 lbs.
350 HO
Long Branch Manifolds
TH350
3.23 open BP axle
PS, PDB and Deluxe interior
GPE Starter ... Small body HEI ... 2.5" Pypes w/X-pipe ... Ruggles Qjet
14.1 @ 99.1
Old 10-23-2004, 08:28 AM
Oreif's Avatar
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by almeyer:
Nicely done. How hard was the project? Did you have to fabricate a number of parts or were you able to buy most of what you needed? <HR></BLOCKQUOTE>
Actually there is no fabrication at all on my part. You just buy the installation kit. All the parts (mounts, brackets, flywheel, starter, 4-core radiator, etc) are included.
You can order a kit from: www.v8archie.com
He sells a basic kit which just has the major parts needed or you can buy the Master kit which includes everything.
1986 Fiero SE
Now ZZ4 Powered!
Old 10-23-2004, 08:33 AM
Oreif's Avatar
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by TD:
Wish you were closer I'd love to ride shotgun through a few curves! <HR></BLOCKQUOTE>
I gained about 30 lbs. The original 2.8L was with an auto trans. I now have a manual trans. So the engine actually weighs 80 lbs more, but the manual trans weighs 50 lbs less than the auto. So total weight gain was only 30 lbs and I gained 215hp.
1986 Fiero SE
Now ZZ4 Powered!
Old 10-28-2004, 10:55 PM
judge_jury_executioner_69 judge_jury_executioner_69 is offline
there was a guy at the track that had a 350 ina fiero. bad thing is that he didnt change the tranny. you shoudl have heared when it changed gears. im suprised it held up the whole night. that was really hurting him and he was still running low 13's
Greatest Of All Time
