Old 10-15-2004, 04:36 PM
sub4600 sub4600 is offline
I have a pretty good oil leak coming from somewere on my engine, it is only on the left hand side (passenger), not coming from valve covers, but lower on the block somewhere but can't see it, any suggestions on what this could be? Thanks
Old 10-15-2004, 05:51 PM
Verdoro 68's Avatar
How low on the block? It could be the oil filter adapter. I had one that was cracked and would leak a slight amount. It could also be the oil pan gasket - or worst case the rear main seal.
I had a combination oil pan leak and filter adapter leak on my car it would leave some pretty good puddles.
Ken
'74 Ventura 350
'69 AMC Javelin SST
Old 10-15-2004, 09:17 PM
Looks pretty low near the motor mount area, but it is leaking pretty bad when I drive it and is blowing back on the exhaust pipe and smoking. Thanks for the info, will check out those two areas.
Old 10-15-2004, 10:06 PM
Verdoro 68's Avatar
Another thought based on your description of the location is that oil could be blowing out the dipstick tube. What are the stats on the engine in your car?
It's probably best to clean the right side of the block off as best you can, take it for a short drive and inspect the block for wet spots. Good luck.
Ken
'74 Ventura 350
'69 AMC Javelin SST
Old 10-16-2004, 11:35 AM
Thanks Ken, cold here today so will have to wait for a little better weather to check it out.
Old 10-16-2004, 05:57 PM
Oil pressure sending unit is a possibility too. It's on the oil filter adapter with a wire plugged into it.
Ken is correct in that the best way to find an oil leak is to thouroughly clean the engine of all oil then watch closely for where it shows up again. Look for the highest and most forward place that oil shows up because it will always travel down and back, never up and never forward.
Old 10-17-2004, 08:38 AM
kaysersuzuki's Avatar
kaysersuzuki kaysersuzuki is offline
could be dipstick tube if up near motor mount,rotted,broken,out of hole
home of the never ending list of pontiacs
2 69 gto converts
1 69 gto htp auto trans
1 69 gto 4 speed
1 69 gto judge
1 75 ta
1 79 formula
1 80 formula
1 81 ta
1 89 formula
1 96 ta
1 66 mustang
1 84 mustang
1 89 25th anniv mustang convert
[email protected]
Old 10-17-2004, 06:52 PM
judgeITO judgeITO is offline
Buyer,
This may be a stretch, but it may be coming from a leaky fuel pump gasket and while running the fan pushes the oil all over the underneath area amking it look like a passenger side leak.
Good luck. ITO
Old 10-23-2004, 04:19 PM
taximan's Avatar
taximan taximan is offline
check the location again. It's a good bet a rear main seal leak. I haven't seen a GTO with a rope seal that doesn't leak yet.
