Old 05-23-2004, 04:27 PM
grandville455's Avatar
grandville455 grandville455 is offline
We'll as you all know I installed that other cam and wasn't too impressed with it as it put my car out of its power range ,but on the recommendation of Mr.Hand I reset my centerline to 106 instead of 108 1/2 and installed rhodes lifters...I didnt take it out to the track or anything ,but I did take it around the block ...Roads were wet so couldnt get a good feel but all I can say is wow!!! It idles now with 14 inches in drive where before it had between 10-8 inches!And it feels much more responsive!!!I can hardly wait to try her for a full run!!
Thanks Jim!!!
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,[email protected]@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected]
M/T 275/60 ET SS Drag Radial
2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's
Thanks Jim!!!
Darby
Old 05-23-2004, 10:42 PM
Doug Christie's Avatar
Doug Christie Doug Christie is offline
I'm almost 11's with that grind (2802) right? I'm 1100 lbs less than you are. You'll be 12's.
"For some reason a glaze passes over people's faces when you say "Canada". Maybe we should invade South Dakota or something."
Old 05-24-2004, 03:43 AM
Hey Doug its the wolverine 1096 same specs as your 1175 ,112 LSA, 2802 is 114....12's hmmmmmm maybe some day once I get it all figured out,lol.....I think I will need the stall loosened up to about 2600 or so then it should be a romper Did you get your problem figured out?
Darby
Old 05-24-2004, 07:45 AM
Darby, I went my fastest with a stock converter. The rhodes should give you pretty good bottom end to launch the "Titanic".
Don't know if I have the problem solved yet, but I did set the engine back in the engine bay this weekend and am going there today to bolt it all up and get it running. Can't help thinking that it's a fuel problem that caused detonation. Good luck going low low 13's.
Old 05-24-2004, 08:46 AM
Trips4me's Avatar
Trips4me Trips4me is offline
Send a message via MSN to Trips4me
And I had to hear about here on the forum... no e-mails about how excited you were....LOL.. Just kidding, Grand!! Glad to hear that you are happy now... had me worried a for awhile there! Jim
Doug.. .let's get that monster running again!!
1965 GTO Hardtop - Fontaine Blue, Blue interior, 389 Tri-Power, 4 speed, 3.36 posi, Rally I's
Old 05-24-2004, 09:38 AM
Jim, It'll be growling by days end!
Old 05-24-2004, 10:22 AM
GS470 GS470 is offline
Very , Darby!! Can't wait to hear how it goes on your next trip to The Rock!
'72 LeMans 2Dr Hardtop
My first car, purchased in 1980
468 Stroker / KRE 315 / HR cam by SD Performance, Tremec TKO II 5spd
'96 Corvette Grand Sport (#470 of 1000 built)
Mildly modded LT4, 6spd
'07 Corvette Z06
Mildly modded LS7, 6spd
'67 Chevelle Convertible
LS6 (405HP Z06), 700R4
Old 05-24-2004, 10:39 AM
Thanks Guys Sorry Jim I wasnt thinking clearly,lol....Next race is the 13th,but will have to do some fine tuning before then,hmmmmm I guess any back road will work .....good luck Doug hope everything works out for ya! Hey Todd it definately feels alot better,but as usual the track will tell it all
Darby
