Old 07-25-2003, 02:23 PM
Likametal Likametal is offline
ok i have a 1973 chevy truck with a creat 350 and a TH 350 with a stage 2 shift kit which i got into an accedent with. the frame is bent and may not be able to be reparied. now i also have a 1968 pontiac firebird with a 400 and a TH 400. the tranny said bye to 2 gear and the motor said bye to the #2 con. rod wich put a hole in the block and a twist in the crank. so now a have a truck with no body and a firebird with no motor. so....... i wanted to know what i will have to do to put the chevy motor in the firebird. motor mounts? tranny mounts? drive line?
Old 07-25-2003, 08:13 PM
pontiarrg pontiarrg is offline
motor mounts and crossmember and possible driveline issues though mine worked okay. Starter is on other side so wires are different. serious performance issues. I had a 67 with a chev 305. After the 400 went in I was much Happier and now that the 455 is in with nos I am smiling
No GTO doesn't mean garbage truck option!
