Old 01-04-2005, 11:40 PM
J_JAMNIK J_JAMNIK is offline
I have a beat 1978 Olds 98 with a factory Olds 350 engine that is basically trash. I have a second Pontiac 400 engine from a 68 Bonneville(only one set of motor mount holes in eash side of block). Without going too deep into my pockets financially, I would like to install the motor into the Olds. The only problem that I think that I will have is the motor mounts. Which year model mounts and for what type of car? Any other problems that I may be overlooking? Once the car is toast(3/4 of the way there already) I will take the engine/transmission out and donate the car. Time isn't the problem, but would like to keep the project under $200 if possible.
Junk is something you've kept for years and throw away three weeks before you need it!
Old 01-05-2005, 06:40 AM
Jeff Walker's Avatar
Jeff Walker Jeff Walker is offline
I doubt if you will find any factory mounts that will make this a 'bolt in' swap. You will probably have to fabricate something up to make the swap.
North Dakotas fastest REAL GTO
10.10 @ 131 MPH in the 1/4
Hoping to get it back together some year.
www.jandjrepairandrestoration
Old 01-05-2005, 09:27 AM
most resto/preformance vendors sell an install kit for the early blocks to the late chassis.
they aren't much money and work well.
mike
former." --Albert Einstein
- Winston Churchill
Old 01-05-2005, 06:07 PM
I'll try to locate something if its available. Thanks for the input.
