Old 08-07-2003, 02:25 PM
Blackfoot Blackfoot is offline
I striped a sub frame down this afternoon that I want to build up for my firebird. I noticed that the passenger crossmember looks like it took a pretty good hit at one time in its life. ( I can fix that) I started cross measuring from diferant points and it seems to be racked about 1/2 " from all points of measurments that I took. Do you think that is too much and should be racked back to a closer tolerance or will the front end alighnment be able to compensate for the racked frame? Its not twisted because it lies flat on the garage floor and floor to frame measurements are all real close. I'm planning on running all Global West A frames with S/S Disc brakes. Before I have it acid dipped, sand blasted and powdercoated I'd like a little more input on the subject. Thanks for your input!
I've got a babys brain and an old mans heart,..............
Old 08-07-2003, 11:21 PM
cstevens cstevens is offline
I woulg pack it down and pull it straight . The wheel alignment may not be much of a problem but for the sake of the body alighment, may make things easier when it comes time to put it back together, plus its simple to throw iton a rack and pull straight while its apart
