Old 01-26-2004, 10:35 AM
BOWE62 BOWE62 is offline
Are the stock t400 cooler lines supposed to be steel all the way to the radiator on a 67 gto. Mine are steel until about 1 foot from the cooler then they go to rubber with 3 hose clamps on each side where they connect, of which one is leaking. 5/16 rubber lines might be wrong size/too big. I put a new 5/16 with 2 hose clamps, leaking again at same spot. Do you guys have 1/4 rubber on there...Did previous owner cut these lines and with new tranny/radiator and there never was supposed to be rubber. Don't want to lose fluid and fry my firm shifting 400( although then I would have good excuse to go to a 200 r4 ) thanks for all your help greg
Greg Bower
Greg Bower
Greg Bower
Greg Bower
Old 01-26-2004, 10:42 AM
wheelspin's Avatar
Greg,
You are correct, they have been cut. I would replace the rubber hoses and clamps to be safe until you opt to replace the trans. New steel or stainless lines are available.
Les
66 GTO Coupe,455/trips,700r/2500stall,12bolt/3.08,1.79/13.01/104.5
68 GP daily driver and 2004 Route 66 Tour participant under restoration
Better lucky than good
Les Iden
Old 01-26-2004, 10:54 AM
Les, Where can I get the right lines? PY, Year One, Ames carry them, junkyard from other similar cars?
Greg Bower
Greg Bower
Old 01-26-2004, 12:10 PM
Verdoro 68's Avatar
Pretty much any of the places you listed has them as well as Inline Tube, Fine Lines and The Right Stuff. If you aren't into 100% originality I'd recommend going with stainless steel lines since they won't rust.
Ken
'74 Ventura 350
'69 AMC Javelin SST
Old 01-26-2004, 01:35 PM
Since someone cut my tranny lines previously to install a new radiator, does that mean that the original radiator had the inlet and outlet lines on the same side, versus the radiator on the car now has one on one side and one on the other...
Greg Bower
Greg Bower
Old 01-26-2004, 04:09 PM
wheelspin's Avatar
Greg,
67 GTOs had both trans outlets in the bottom of the downflow radiators, 68 up models had the outlets in the crossflow radiators on the passenger side. I have seen this mod before and it is usually the result of some shadetree shortcut.
Les
Les Iden
Old 01-27-2004, 11:43 AM
Ok, thanks Les, now I know to order the lines for a 67 gto
Greg Bower
Greg Bower
