I HAVE A 71 LEMANS WITH THE 350 PONTIAC ENGINE.
IS IT POSSIBLE TO CHANGE THE ROCKER STUDS AND ARMS SO THAT I CAN ADJUST THE VALVES LIKE YOU WOULD ON A SMALL BLOCK CHEVY? ARE THE STUDS IN MY ENGINE A SCREW IN TYPE OR ARE THEY PRESSED IN? ANY HELP WOULD BE APPRECIATED. |
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core.
We need the casting # from the heads to know what studs are in them. You can use locking nuts and spacer washers to make your rockers ajustable with either screw in or press in studs. If you have a stock cam I would not advise doing it. When I bought my performance Crane cam (272-2) it came with locking nuts and washers to use.
Greg 1969 Firebird/400/th400/3.42:1 rear 1/4=? MPH=? (WIP) 1983 1/2 ton Silverado/lwb/305 (89 FB)/ MSD ign/Mallery coil/83 intake/ 700-r4(rebuilt w/shift kit and corvette servo)/ 3.73 gears/31x10x15 all terrains. 10.9 1/8 mile. 17.xx 1/4 mile 1996 C2500/6.5L TD/4L80e(shift improved),4" exhaust cold air intake, mechanical WG controller 3.73 gears/265-75-16 w/Eagle allows. 2002 1500 Suburban/stock 1986 Fiero GT,needs engine. |
