Old 06-17-2004, 08:40 PM
chief many horses's Avatar
chief many horses chief many horses is offline
I'm converting a 62 GP from Roto to a t-10 and am having a heck of a time finding a rear trans mount assembly. What is the possibility of moving the cross member forward enough to use the lower trans. mount boss of the t-10 along with a full rubber mount? Would this cause any complications? It surely seems like a better mounting setup. Thanks~
Old 06-17-2004, 09:08 PM
tom s tom s is offline
they show up on ebay quite often.Make sure your trans has the 5 holes shifter mounting tail housing.The tab on the trans mount goes into one of the unused holes.Tom
The Following User Says Thank You to tom s For This Useful Post:
Old 06-17-2004, 09:23 PM
I've got the correct t-10, (date coded 11-61) with the hole for the mounting tab. I can't seem to bid fast enough on e-bay at the last 60 seconds when the bids go from $100 to $160 whew!Guess I should just put in a $500 bid from the gitgo that would shake them up! Anyway that's why I was wondering if the forward mount would work. Thanks for the food reply. Rich~
Old 06-17-2004, 09:35 PM
esnipe,set the max your willing to pay and forget it.Tom
Old 06-22-2004, 06:37 PM
Thanks Tom, I'll gladly try it.
Old 06-22-2004, 08:18 PM
61man 61man is offline
If you move the cross member forward, you will have to do something with your emergency brake cables, one adjuster hooks to the cross member, There are a couple of other choices, 1. Use a long tailshaft T-10, 2. Contact Brad Duerst at Fabcraft, he is making a lot of stuff for 61-2 straight shift s, I think that he is making the piece that you are looking for. His email is bduerst@attg.net
Old 06-23-2004, 09:28 PM
62gp 62gp is offline
Send a message via ICQ to 62gp
I recently did what you are suggesting on a 62 gp with a Muncie. Moved the crossmember up one hole and drilled new front holes. Fabbed a 1/4" steel plate, used the full rubber mount under the transmission. Had to shim slightly to correct pinion angle. Far better mount, I beleive, than the tailshaft mount. No problems so far - Lewis
Old 06-24-2004, 07:39 PM
Now that's what I like to see,- good ole Yankee enginuity! Thanks much~
Old 09-30-2022, 06:16 PM
mgarblik mgarblik is offline
My 62 Catalina was converted exactly that way. I also have a Muncie but T10 should be exactly the same. I made 2 new E-brake hangers from 3/16" rod from Menards. $1.79 for 3 feet. Works fine. My conversion was done probably 15 years ago before I bought the car. One of the few things I haven't had to re-work.
Old 10-03-2022, 11:55 AM
webfoot's Avatar
webfoot webfoot is offline
This thread is old enough to vote FYI..
I used a chevelle crossmember and welded about 2" of plate to each side, now I can use a more typical trans mount and have cutouts for dual exhaust to clear.
-Jeremy
1968 GTO 4-spd convertible, console, factory gauges, hidden headlights, 3.90:1 posi, AM/FM radio.
1962 Catalina convertible, Starlight black w maroon interior & white top.
