Old 01-22-2004, 07:39 AM
BOWE62 BOWE62 is offline
I just put new valve covers with new cork gaskets 5 months ago yet I see a light stream of oil towards the back of heads eventually running down on the exhaust manifolds. Any suggestions? Its a 65 389 on a 67 gto
Greg Bower
Greg Bower
Greg Bower
Greg Bower
Old 01-22-2004, 08:10 AM
Cardo's Avatar
Cardo Cardo is offline
Order the 5/16 thick valve cover gaskets from Indian Adventures Racing. I put them on my car with a small bead of RTV Black Ultra Permatex on each side and haven't leaked a drop since! I always order 2 pair since you are paying the shipping anyway. I never could get a regular set of cork gaskets to not leak. At least not for long!
"Not knowing, I hesitate to respond."
"I know just enough to keep me here, but not enough to get me out"
Old 01-22-2004, 08:12 AM
wheelspin's Avatar
Gage,
Try it again, but this time use Fel-Pro rubber gaskets (#VS50005R). Lightly silicone the gaskets to the v-covers and grease the gasket to head surface. I have reused the same rubber gaskets without leaks in my 455 and 400 for more than 4 years.
Les
66 GTO Coupe,455/trips,700r/2500stall,12bolt/3.08,1.79/13.01/104.5
68 GP daily driver and 2004 Route 66 Tour participant under restoration
Better lucky than good
Les Iden
Old 01-22-2004, 08:30 AM
tikiklubracing's Avatar
tikiklubracing tikiklubracing is offline
You've probably over tightened at some time trying to fix. Take cover off and hold it up and look down the sealing flange. it's probably bent. You need to rebend it with light hammer taps all the way around until the flange is straight at the gasket mating surface. Pay attention to the holes, they are probably bent inwards too. Clean until you can eat off the mating surfaces. I use the perma-seal gaskets, they have sealing stuff on the mating surface already. Then go with studs with nuts that have a washer face. No more than 15 ft. lbs. This fixed mine Good Luck!
"Somebody sell me a 78 Catalina grille, please",15 yrs in NHRA tech ret. 413 rpm 4150 3.73 hoosiers 13.54 4050# Winter Sucks www.nhra.com www.ihra.com
NHRA tech.
"Its just a 412, I swear it".
Pontiac tip of the year, quit those damn cigarettes.
Old 01-22-2004, 08:44 AM
flea flea is offline
Send a message via Skype™ to flea
Ditto what Wheelspin says. i ran Felpro rubber gaskets glued to valve covers and adjusted my valves about once a month for a couple of years and never had to replace gaskets.
Old 01-22-2004, 09:13 AM
tievom tievom is offline
I ran into the same thing on my 71 GT-37. The cork gaskets are usually 3 pieces glued together. The seams are about an inch from the end of the gasket and will pull apart about an 1/8 of an inch (due to the heat I believe).I'm using a rubber gasket now and have not had any problems.
Old 01-22-2004, 04:45 PM
PONTIAC DUDE's Avatar
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by pittsburgh 64:
Did you put the lip side of the valve cover on the bottom.<HR></BLOCKQUOTE>
Yes. Some intake/valve cover combos need to have the lip of the cover ground as the intake ports keep the valve cover from drawing tight, even with the thicker Felpro Performance VC gaskets.
Some have recessed and some do not.
I've used the Felpro Hi-Perf gaskets for 15+ years without issues.
Build it fast, build it right, build a Pontiac.
http://PontiacDude.cc
Old 01-22-2004, 05:25 PM
Tom Vaught's Avatar
Boost Engineer
Ken, you have mail.
Old 01-22-2004, 05:33 PM
Not yet. Must be the snow.
Old 01-22-2004, 05:57 PM
Check the time.
Almost a 1/2 hr. still no snail mail. LOL.
