I took my 64 out for its first voyage since doing a frame off and noticed that the speedo is not reading correctly.
I took the original 300 out and replaced it with a TH350. The speedo is reading about 13 mph faster than what I an really going. Can I take the speedo gear out of the 300 and put it on the TH350? Thanks, Jim http://www.geocities.com/jims64gto
http://www.geocities.com/jims64gto |
I think you will have to change the gear on the output shaft to correct your seedo.
Greg 1969 Firebird/400/th400/3.42:1 rear 1/4=? MPH=? (WIP) 1983 1/2 ton Silverado/lwb/305 (89 FB)/ MSD ign/Mallery coil/83 intake/ 700-r4(rebuilt w/shift kit and corvette servo)/ 3.73 gears/31x10x15 all terrains. 10.9 1/8 mile. 17.xx 1/4 mile 1996 C2500/6.5L TD/4L80e(shift improved),4" exhaust cold air intake, mechanical WG controller 3.73 gears/265-75-16 w/Eagle allows. 2002 1500 Suburban/stock 1986 Fiero GT,needs engine. |
trt www.triauto.com they have all the stuff you need to fix your speedo.
