Old 08-14-2003, 08:08 PM
longboard longboard is offline
Does anyone know of an electric fuel pump that fits into the gas tank for 60s cars? If not does anyone know of a quiet electric fuel pump, or how to make one really quiet?
Deane
Deane
Old 08-14-2003, 08:16 PM
Crashmh's Avatar
Crashmh Crashmh is offline
I don't know of an in-tank style pump for a carburetor application, but the quietest electric pump that I've used is a Mallory Comp Pump. Mount it with rubber isolators and you won't know it's there! With the car off on the pump running, I had to bend down at the rear of the car to hear a slight electric whir.
Old 08-14-2003, 08:33 PM
Tim Corcoran's Avatar
The best thing to do is go down to your local auto parts store and get an AC Delco stock replacement fuel pump for your make and year vehicle. They are cheap, reliable and more than adequate for most street strip cars. Unless you are running in the 11's or faster there is no reason to run a noisey electrict fuel pump anyhow. Save your money and get your quiet ride the smart way.
Tim C
65 LeMans, 3500lb. D-ports and a flat tappet cam, 10.92@120
Tim Corcoran
Old 08-16-2003, 02:27 PM
Kenth's Avatar
Kenth Kenth is offline
Carter P4594 with quiet pack.Slight buzz.
Got one feeding my -70 four bolt 455" .030 with slightly ported -71 #96 heads #744 cam std intake with a SD replacment Q-jet #17054910.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 08-16-2003, 03:58 PM
FirebirdDave FirebirdDave is offline
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by Kenth:
Got one feeding my -70 four bolt 455" .030 with slightly ported -71 #96 heads #744 cam std intake with a SD replacment Q-jet #17054910.<HR></BLOCKQUOTE>
I have run that pump before. I works pretty good.
69Firebird roundport/roller455
70Catalina 455
72Skylark Buick 455
89 Iroc 305 stock 192RWHP/263RWTQ
I cant leave anything alone.
336rwhp/425rwpft
12.62 @ 108.60
70Catalina 455
72Skylark Buick 455
