Old 08-02-2004, 05:30 AM
crkoester's Avatar
crkoester crkoester is offline
Need to replace my 69 dash, and it appears no repros are being made (probably old news to the rest of you 69 guys). I'm looking at these repro dash caps that everyone sells (I assume they are all the same?), that you glue onto the top of your old dash.
Has anyone used them? Are they worth a dang? How is the install? Durability?
I need one in black, A/C w/ side vents....
I know you can get a very nice dash from Just Dashes, but for a $500-600 difference in price I thought I might consider one of these caps first. Building a nice driver, not a show resto.
Chris
69 GTO Hardtop project - started without a clue, will finish only by the grace of the PY Forums and Mr. Dave Wrzesinski (magicV8) - candidate for Father-In-Law Of The Century.
We are building a bad-ass, hot-looking, hot-running Pontiac street machine.
crkoester's Avatar
Chris
Old 08-02-2004, 06:02 AM
71 T/A 71 T/A is offline
I have one on my 69 with a/c. They're good quality. Not only does Just Dashes charge you the $500-$600 BUT YOU PAY $35-$50 for shipping.
Old 08-02-2004, 10:35 PM
imctjt imctjt is offline
Excellent product! I put one on my '69 GTO dash w/ac and you cannot tell it is not the original dash unless you know that the dash was soft and not a hard plastic. If you are doing a consourse show car it will not do, but for a driver or resto they look great. Simple to install, durable and great fit.
Old 08-03-2004, 08:24 PM
68MeanVerdoroGreen's Avatar
68MeanVerdoroGreen 68MeanVerdoroGreen is offline
I agree with imctht 100%!
Larry Metzger
Columbus, NJ
1968 GTO Verdoro Green Hardtop
1969 GTO Palladium Silver Hardtop
1969 Judge Carousel Red Hardtop X 2
Someday We'll Look Back On This And It Will All Seem Funny.
From Rosilitia, Sung By Bruce Springsteen, CIRCA 1973
Old 08-04-2004, 08:20 PM
crkoester's Avatar
Thanks a bunch for the replies guys. I'm going to try it.
Another question: my original dash is badly sunbaked and extremely brittle - moderate pressure from a single finger can easily crack right through it on top. Do you think I will have issues with stability/adhesion with the plastic cap, with it breaking pieces of the old dash away from the foam core along the top edge? Or should it stay together OK? Anyone glued on onto a snap-crackle-pop old dash like mine?
Chris
Old 08-04-2004, 10:27 PM
Chris - My dash was very dried out and brittle. Since the cap is one piece, it has a lot of structural integrity to it. I sanded the dash and prepped it with paint prep to take all the old treatments off it. I made sure any high areas were sanded down and then glued it. It's been on a year and it still looks great. Just take your time, and make sure you heat up the silicone adhesive in the tube so it flows easily. Also, use clamps, bungee chords, towels, etc. all along the cap to make sure that all areas are firm against the dash so you get a good glue job. If you do it right, I promise you that you will be happy with the results.
Old 08-04-2004, 11:09 PM
crkoester's Avatar
EXCELLENT. All very helpful information. Thanks so much you guys. With your help, I'll get through this with a minimum of headaches.
Chris
Old 11-29-2004, 05:37 PM
Guy Mazza's Avatar
Guy Mazza Guy Mazza is offline
I installed one on my 69 GTO racecar. If I didnt point it out to ya, you'd never know. Definately, "good enough"
Id use 'em again....
~Guy
Old 11-29-2004, 08:25 PM
PonchoV8 PonchoV8 is offline
How much is it? From where?
Old 11-29-2004, 10:38 PM
Guy Mazza's Avatar
....they are "appx" 100.00. I have seen them on Epay, or even JC Whitney (no ****!) ~Guy
Old 11-30-2004, 05:03 AM
Try these folks-
http://www.dashcaps.com/default.htm
Old 12-01-2004, 05:30 PM
Bill93711 Bill93711 is offline
Do it right--the caps look like crap.
Old 12-01-2004, 05:37 PM
Guy Mazza's Avatar
...I disagree. For a "driver" the caps are fine. Maybe Mr. Bill will "do-it-right" and buy you a 700.00 (+shipping) dash from Just Dashes!!
Old 12-02-2004, 07:53 PM
Actually Im getting mine from from Just Dashes next week. $600---but I guess if you count the $100 I wasted on the cap--it was $700.
Old 12-02-2004, 11:38 PM
Just curious Bill, What kind of problem did you have with the cap?
The ones that I've seen looked good and I couldn't tell it from original until I looked closely at the edge and kind of tapped it with my finger to find that it was hard plastic instead of a pad.
Later, I mistook and authentic pad in a '70 el Camino for a plastic cap until the owner pointed out that it was the original.
Old 12-03-2004, 06:16 AM
Guy Mazza's Avatar
Im sticking to my guns on this one. PROPERLY installed, they DO look good. We even installed one on a MBZ 450SL, and it too looked good. Not "Factory fresh" mind you, but "good". If you are super-anal, Just Dashes as Mr.Bill is doing is great, but if you actually drive your car, and want to spend the extra 500-600.00 on something else. Go for da cap.
Old 12-03-2004, 03:55 PM
Maybe Im a perfectionist on this issue--but as complicated as a 69's dash is, it is very difficult to get these caps to fit correctly around all the dash openings, especially the center AC vent. I guess if you got a perfect glued seam around this opening and the speedo, etc, it might look OK. But without that--I could always see the lose seam. Maybe other people couldnt tell(or just didnt look), but I could. On mine, I didnt realy need a dash cover around the gauges and AC vents to start with, it was just bad on the top. Too bad they dont make one for 69 that would just cover the top and not extend around the multiple openings on the front of this dash. Anyway--I ripped it off---the new restored dash looks great sitting on my work bench right now.
Old 12-03-2004, 06:08 PM
Well, I'll admit that the ones I've seen were just top pads.
Old 12-03-2004, 09:37 PM
They might look OK where you are only covering the top of the dash. They look like crap on a 69.
