Hey Guys,
As stupid as this sounds, I am contemplating getting rid of the T tops in my TA and going to a Hard Top because fo the Speed and amount of power that will be induced on this car. Before it was a low 13s high 12s car, when all is said and done I am looking at a mid 9s car and I am a little wary about those T-tops coming loose on me. While I will have a full cage with bars into the engine compartment, I am not too worried about twisting issues, but I am thinking those guys may blow away...LOL. Has anyone attempted, seen, or accomplished this insanity before??? It really does not seem like too daunting a task. What do you guys think??? Am I insane??? Thanks in advance, Dave (Bandit)
403 afficionado...made it my personal quest to maximize the power potential of the 403. www.fcrperformance.com |
Hey Guys,
i know you could do a roof transplant. but a guy i know from work has a 77 z28 that had t tops and the orignal owner welded some metal into the t top holes and filled it up. I would imangine it would take some decent amount of body work
Good luck at your car shows hope you win 1st in the Stock Compact everyday driver nothing special about me class. Or the i want to go fast but cant afford a good car so i buy this crap and put in a sound system cauz the bass gets my A$$ down the stre |
Thanks for the advice...I would like to go the full top transplant though.
Hey it is your car, your money so make it the way you want it!
1979 400 / 4spd. tenth anniv. project in the works. |
After seeing the poor quality of T top gaskets out there and chasing a T top leak for a year on my son's 81 TA driver I understand completely. My 78 currently runs high 10s with T tops and never popped one out.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
yeah I replaced gaskets three times before I finally got most of the leaks stopped.
im having the t top gaskets replaced in my car right now while its getting pianted. I used the metro seal gaskets which i hear are the best for t tops right now. If you use the GM seals your only asking for leaks because they are in such bad shape its sick. and besides a leak shouldent bother ya if you dont drive it in the rain, and when you wash it put a towell in the car
