View Poll Results: Poll question
1 3 100.00%
Voters: 3. You may not vote on this poll
Old 08-20-2003, 07:00 AM
263S 263S is offline
HI I WAS WONDERING HOW YOU PUT A V8 IN THESE CARS.DO YOU USE A V8 CROOS MEMBER OR CAN YOU USE THE 4CLY CROSS MEMBER.
Old 08-24-2003, 04:17 PM
Tom Cheatwood Tom Cheatwood is offline
I have a 63 v8 crossmember in my 62. But a friend of mine used a 4cyl. in his modifying the 4 cyl. mounts to solid mounts to mount his 455.
Tom Cheatwood
62 tempest 455
68 GTO 400
Tom Cheatwood
62 tempest 455
68 GTO 400
Old 08-25-2003, 12:42 PM
White Warrior White Warrior is offline
The best solution is to use a 63 V8 crossmember. This will bolt right up to the V8 mounts and will put the engine in approx 1" offcenter away from the steering rod giving you more exhaust clearance on that side. The 4 cylinder mounting position is 1" the other way offcenter. It can be made to work,tho.
Old 08-25-2003, 09:35 PM
63Longtop's Avatar
63Longtop 63Longtop is offline
Matt, ditto to what Dave said. I have a 63 V-8 crossmember if OPH doesn't want it anymore. I would recommend using the 4 cylinder springs for a proper ride height though. When I pull the mocked up motor back out of my car, I can send you the way mine has been set up. JIM
Old 02-19-2004, 10:08 PM
iwanna63lemans/tempest iwanna63lemans/tempest is offline
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by Jim Linenberger:
he way mine has been set up. JIM<HR></BLOCKQUOTE>
Hi Jim,
I'm looking for a '63 V-8 crossmember and yor name popped up. Do you still have it for sale?
thanks, Mike
2'63lemans
Old 02-20-2004, 07:41 AM
RA6T7GOAT RA6T7GOAT is offline
hey guys
i am getting ready to put a 455 in my 63,sounds like i need a v-8 cross member for my 63 (mine orig a 4 cyl) any body got one to sell ?
Old 02-20-2004, 08:23 AM
tom s tom s is offline
I used the 4 cyc X member that was in my cars.We made mounts that bolted to the original 4 cyc mounts,was not a problem.I also moved the motor toward the pass side on one car to make room for the hyd clutch master cyc..Tom
