I've got a 64 GTO with a 400ci motor, 670 heads, power steering, and a 4speed. I'm looking at either Hedman, or Hooker Super Comp 1 3/4" headers. Is one better than the other? Is there something else I should be looking at? I'm on a somewhat limited budget. Thanks.
If you want cheap, will probably leak, a real biotch to install and will hang down low so every speed bump or dip in the road you will ding them then purchase Hedman or Hooker.
Otherwise purchase a set of Doug's Headers that will be easy to install, won't leak, increase your performance, and will tuck up close to your floor boards and look good for many years.
![]() Due to the current economic conditions...the light at the end of the tunnel has been turned off. Meet you at the finish line.....don't be late! |
Don't hold back, Ron
Thanks for the heads up.
Hmmm.. Now WHERE did this part go??? |
