Old 09-17-2003, 05:03 PM
Dave Smith Dave Smith is offline
I recently had a engine built for my 69 GTO.
We used a 1974 400 block, 13 heads, and 068 cam. The engine was bored 30 over and new pistons, rings were put in.
My problem is that the engine seems to turn over very hard and will crank very slowly. The battery will go dead if you crank more than about 30 seconds even with a battery charger hooked up and set on starting boost.
The engine was run long enough to break in the cam and then driven home (about 5 miles).
Will this engine loosen up when it is driven more or is something misaligned?
The battery is 500+ cca but is only 1 year old, and I don't think it should go dead this quickly.
Any suggestions greatly appreciated.
Love is like oxygen. Get too much, you get too high; not enough, you're gonna die.(Sweet)
Old 09-17-2003, 05:54 PM
Blackcat's Avatar
Blackcat Blackcat is offline
Bonker's-T-Cat Moderator
Get a bigger Battery!
You need at least 800 CCA!
I normally get the Biggest case and the most CCA I can!
I normally run 1000 CCA
Usually I'm found working on my Pontiac. If you want to find me Look for the white picket fence and all the old Pontiacs parked outside. And the half dissembled engine sprawled all over the driveway!
Try calling CRUSHPROOF! 512-386-9889
Old 09-17-2003, 09:16 PM
Bud Lyons's Avatar
Bud Lyons Bud Lyons is offline
Send a message via MSN to Bud Lyons
I have an 1100cca spinning my 462.
My Rig's a little old, but that don't mean she's slow.
WWW.PatriotGuard.org
Standing for those that stood for us.
Only two defining forces have ever offered their life for you, Jesus Christ and the American G.I.
One for your soul; the other for your freedom
Old 09-18-2003, 12:47 AM
goatseeker's Avatar
goatseeker goatseeker is offline
Dave,
Where is your initial timing set? Have you tried retarding timing a little to see if it cranks easier?
http://kurtspontiac.homestead.com/TimSimpson66GTO.html
Old 09-18-2003, 06:47 AM
gto_guy gto_guy is offline
I agree get a bigger battery.Mine is 1000cca
www.cardomain.com/id/gto_guy
Everyone should believe in something,I believe I`ll have another drink.
Old 09-18-2003, 10:17 AM
gold79TA gold79TA is offline
Same thing happened to me. Turns out the new headers finished cooking the old starter causing it to draw too much current. Rebuilt starter fixed the problem but only lasted about a year and a half.
Old 09-18-2003, 05:21 PM
6t7goat 6t7goat is offline
I had the same thing happen to me. My car started great until I rebuilt the engine. When I put the new engine in I constantly had to jump start it. I put in a 1000 ca battery and have yet to have a problem. As it turns out my old battery was only putting out about 375 amps.
Old 09-18-2003, 05:42 PM
basketcase70gto basketcase70gto is offline
A guy I know told me a story of his neighbor rebuilding a sb mopar. His neighbor came over and asked if he would come over a look at his engine because it was hard to turn over. When the got there his neighbors kid and a buddy had a 36" pipe wrench and a 5' bar on the balancer and the kid was cranking the starter and it still wouldn't turn! Turned out they put all the connecting rods in with the chamfers facing each other. They also said the rod caps would not slip on by hand to whole way so they cranked the down with the nuts. Some people should not pick up tools.
Old 09-18-2003, 06:24 PM
STripleduce's Avatar
STripleduce STripleduce is offline
With the plugs out put a tq wrench on the balancer bolt it should take no more than 40-45 ft lbs to turn the motor.If its more than that I have seen rope seals cause up to 50 when installed wrong.Anything else would require teardown.
http://community.webshots.com/user/stripleduce
Old 09-18-2003, 07:39 PM
1970cat's Avatar
1970cat 1970cat is offline
wouldn't hurt to check your negative battery cable also. may have to scrape paint frrom where it connects to the head.
Old 09-19-2003, 05:38 PM
Lerry: The Body Ventura..'s Avatar
Lerry: The Body Ventura.. Lerry: The Body Ventura.. is offline
Send a message via Yahoo to Lerry: The Body Ventura..
Definitly a bigger battery as mentioned and also check timing as mentioned. Engine is tighter now with rebuild. More compression, more cranking amps. Especially if the old rings were leaking...
