Old 11-12-2004, 11:17 AM
6t7gto's Avatar
6t7gto 6t7gto is offline
how do you guys chain, restrain, tie down your motors.
70 lemans, hoping for the 12's.
and i don't want to break a motor mount.
any pics?
thanks,
david
6t7gto's Avatar
any pics?
thanks,
david
Old 11-12-2004, 11:49 AM
Mr. P-Body Mr. P-Body is offline
Indian Adventures sells a nice set of solid mounts for the A-body. A pair of "plates" that tie the frame to the front of the heads is also a very popular method. Chains and cables are from the '60s...
Old 11-12-2004, 12:09 PM
ventura7211's Avatar
ventura7211 ventura7211 is offline
All pontiac.com front plate, TCI midplate is what I'm goin with.
Old 11-12-2004, 12:29 PM
bmpmdf bmpmdf is offline
My Vega and 69 Firebird are front and mid plate cars now. I got tired of halfway done jobs.
Have A Great Day
Old 11-12-2004, 12:47 PM
6t7gto's Avatar
i looked into the front and mid plates.
don't you get a lot of vibration from this kind of setup?
Old 11-12-2004, 02:19 PM
Depends on what the primary use of your car is, if its mainly strip action then plate it. Street/strip solid mounts and maybe a torque strap, street stock mounts and maybe a torque strap.
Old 11-12-2004, 02:50 PM
6t7gto's Avatar
thanks for the replies.
i think i'll go with the plates and be sure.
david
Old 11-12-2004, 09:03 PM
Jim Hand Jim Hand is offline
Performance Pontiac Author
67GTO,
We modified a stock mount to provide a positive stop while retaining rubber cushioning for normal driving. It has worked perfectly for over 10 years on my wagon. It takes a bit of work and welding but that is what hot rodding is about.
This information is courtesy High Performance Pontiac, August, 1993, and my son Joe Hand. The hardened rod (referenced in the article) we used was a section of an engine mounting bolt.
Jim Hand
Old 11-13-2004, 05:05 AM
Jim's "limiter" is nice and (as with all his stuff) very methodical.
I use a threaded tensioner assembly. Turnbuckle and two hiem ends that have a bracket welded to the passengers side subframe. Use a mount plate that bolts to the three holes in the end of my E-heads. Allows me to preload the engine to a degree.
I would take some pics but the cars all taped/masked up for painting.
Old 11-13-2004, 05:31 AM
Schoust's Avatar
Schoust Schoust is offline
Who sells a torque strap for a first gen Firebird??
Old 11-13-2004, 06:47 AM
455firebird1969's Avatar
Schoust, Someone sells a solid motor mount for the first generation Firebirds, I think it is Indian Adventures? but, I am not sure. The first generation motor mounts have a built in mechanical stop similar to what Jim Hand posted. When you buy motot mounts take them out of the box and ensure you are buying the good ones, because the cheap ones do not have this feature. See it in my pic below.
Note: it is covered in rubber.
Old 11-13-2004, 07:41 AM
lugnutt's Avatar
lugnutt lugnutt is offline
Send a message via MSN to lugnutt
Does anyone make a solid mount for the first generation firebirds?
If its one thing I know, its..... Uhhh I forgot .
What do you mean I couldnt be the president of the United States of America, Its still WE THE PEOPLE, RIGHT!!
Old 11-13-2004, 08:02 AM
6567GTO's Avatar
6567GTO 6567GTO is offline
Great idea Jim. Thanks for posting the article.
_________________________
Sonny Barger
Old 11-13-2004, 08:24 AM
Although the article does not mention it, it will be necessary to heat and bend the tab on the motor mount to allow space for the hardened rod. And the .030" clearance figure is very nominal.
The real advantage of this setup is that we have the positive retaining of the engine under full load, but it does not transfer the roughness and noise into the cabin as does any kind of solid mount. That is not a problem with a race car, but is quite important with a quiet muffled car that will be driven on the street. I tried solid straps, chains, and cables before Joe came up with this idea. And the original mount has now been in service for about 13 years and thousands of dragstrip runs.
Jim Hand
Old 11-13-2004, 08:54 AM
Here is a photo of the modified mount in place. The location and black paint makes it a bit difficult to get an ideal photo. But notice the shiny spot where the added rod has contacted the solid part of the mount (under full acceleration).
Old 11-13-2004, 11:28 AM
ErikW's Avatar
ErikW ErikW is offline
Also, if you go with a mid plate you may have to modify some header tubes to clear the plate. I would go with Hand's mod if you are driving on the street.
Erik
1964 GTO
9.76 @ 137mph
2009 G8 GT
Old 11-13-2004, 11:40 AM
Brian '74's Avatar
Here is Jim's pic that I lightened up to show more detail:
Old 11-14-2004, 07:53 PM
issach428's Avatar
issach428 issach428 is offline
thanks for posting this modification, I drive my car on the street alot and couldnt bring myself to puting solid mounts on it. Thanks again Jim
72firebird 3800# 496 316cfm eheads, 11.1:1 compression, custom solid roller, victor 4500 intake port matched, 1050 dominator, continental converter flash 4400 stall. 3.73. 2 inch headers with 3.5 with x to mufflers reduced to 3 inch full exhaust. mallory 250 fuel pump, cal tracs with split monos ..Pump gas 91 octane.
Old 11-16-2004, 10:05 AM
Schoust's Avatar
69 455,I have already purchased a set of urathane engine mounts from energy suspention,will these mounts do the job?I still have the originals and they look Ok but I was figuring the urathane was the way to go?? The car is a stick and I am worried about a lot of engine rocking and thats why I was woundering about a strap
