Old 12-03-2003, 01:48 AM
harddecisions harddecisions is offline
In the '96 Gran Prix the speedometer quit, and the transmission won't shift. The car runs fine but won't come out of first gear. After several days and a new speed sensor, the transmission shop says it is not the transmission. They say I have an electrical problem. Where do I start looking?
Old 12-03-2003, 07:28 PM
TIAUTOMAN TIAUTOMAN is offline
Check you signal coming out of the speedsensor.
Then check to see if the signal is getting to the cluster. You are going to need a schematic.
The trans will not shift if the cluster is not receving a speed signal.
Scan for codes and see if anything comesup
Old 12-03-2003, 08:01 PM
stevep's Avatar
stevep stevep is offline
I've seen a problem with the VSS connector and have seen the harness melt about 1 foot away from the VSS.GM has a service connector available.
The difference between inlaws and outlaws-outlaws are wanted
Old 12-04-2003, 09:03 PM
Thanks folks, I'll check the connectors......
