Old 11-24-2004, 09:33 AM
smoky smoky is offline
Would i be better off to use a performer intake or a performer rpm on a new 455 ram air 4 cam 4x7h heads and a slightly built quad carb.This is a daily street driver, i have the opportunity to buy a used rpm from an individual locally.Also whats a used rpm worth?
Old 11-24-2004, 09:35 AM
Chris C Chris C is offline
I'd use one. I've got one on my 400 with an XE274 cam. I'm not sure what they are worth.
Drink Beer.
Old 11-24-2004, 09:47 AM
Kybird Kybird is offline
The runners on a performer are actually a little smaller than a stock intake. I have tracked some RPM's on ebay, they easily go in the $150 range.
Old 11-24-2004, 10:18 AM
Larry Navarro's Avatar
Other than a weight savings, the performer is no better than a cast iron intake.
If the RPM is a good price, then get it.
Old 11-24-2004, 10:37 AM
David Holmberg's Avatar
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by Larry Navarro:
If the RPM is a good price, then get it. <HR></BLOCKQUOTE>
+1...
I ran an RPM intake on my 462/RAIV TA and it worked great.
Old 11-24-2004, 12:32 PM
Beebe's Avatar
Beebe Beebe is offline
BE Sure to check your hood clearence with the RPM intake , it is alot taller than the performer.
I run a performer RPM with a 3" drop base 4" Filter and I stll needed my 2-1/4" Cowl hood.
Also Known As "Beebe" on other sites....... PZ , Pro-Touring , Lateral-G, TAC
Old 11-24-2004, 03:49 PM
Bulldog Bulldog is offline
Send a message via AIM to Bulldog
I have an RPM on a 455 in my 68 Firebird and also use the 4X-7H heads. I havent put the front clip back on the car but by taking some rough measurements the RPM is going to give me a little hood clearance issue. May just go with a high-rised 400 hood. But I would deffinetly recommend the RPM like these guys suggested.
A.J. "Bulldog" Murphy, MSgt
Old 11-24-2004, 11:23 PM
455earlybird's Avatar
455earlybird 455earlybird is offline
The performer rpm should clear a 68 400 stle hood with a drop base air cleaner and a 3" filter
67 Firebird Best time 1.53 60' [email protected] 1/4 [email protected] 1/8 3500lb. leaf springs
