Old 01-06-2005, 06:25 AM
"Guy
Send a message via MSN to
My power steering pump started leaking out the seal. I saw in Summitt they offer a pump that has less drag. Is it worth 129.00 or should I just stick with an Automate pump for 49.00? Or is there another pump you guys would recommend?
Guy
"Guy
Guy
Old 01-06-2005, 07:01 AM
Seal kits are avail at most local autoparts stores for under $20. Not that hard to install the kit & by reusing your original pump & p/s pump pulley, you will be guaranteed it fits. Even cheapy rebuilt pumps require you reuse your own p/s pump pulley & there were at least 8 different p/s pump pulleys used on Pontiac V8 pumps from '65-81.
