Old 06-25-2003, 02:42 AM
tiresmoke68 tiresmoke68 is offline
Just to let all of you know, dont waste your time with pertronix ignition, I did in my 68 firebird, and went nuts trying to figure out why it was fluttering through the carburator under a full load, thought it was the valves, adjusted them, then was told it was my carburator, then I called Jim Hand and he said, " Mike, take out the pertronix and re-install your points ignition" and now the car runs greeeeeeeeeeeeeeeeat!!!! thanks to Jim Hand I will now have a great summer.
My wife wants to know "Why do you feel the need to burn the tires like that" I said, its a guy thing honey. :}
Old 06-25-2003, 03:45 AM
PONTIAC DUDE's Avatar
Interesting. Sold quite a few units (and installs) without any problems.
I bet over 50,000+ units have been sold to date...... And all bad?
Build it fast, build it right, build a Pontiac.
http://PontiacDude.cc
Old 06-25-2003, 04:05 AM
Mr_GTO's Avatar
Mr_GTO Mr_GTO is offline
My father had one in his '67 427/390hp Corvette adn it ran like a champ. He drove it from Boston allt he way to the end of Long Island and back and no hiccups at all.
Old 06-25-2003, 04:51 AM
Larry Navarro's Avatar
have one in the SD as well ....no problems, either.
1973 SD455 T/A
1979 S.E. T/A
http://community.webshots.com/album/16587603rOyvmFCiHs
Old 06-25-2003, 05:02 AM
Half-Inch Stud's Avatar
Pertronix ought to work.
However, I use HEI.
HIS
"tbdET/1xxMPH/1.xx 60foot/28"/3.54:1/10"/469 #48/Flat HYD/DualQ-Jets/Offyl/3xx0Lbs
11.00/123MPH/1.50 60foot/29.5"/4.10:1/10"/469 #48/FlatHYD/DualQuad/Wenzler/3250Lbs
12.00/112MPH/1.61 60foot/26"/3.31:1/10"/469 #48/FlatHYD/Q-Jet/Torker/3650Lbs
12.70/103MPH/1.71 60foot/28"/4.10:1/12"/469 #48/FlatHYD/Q-Jet/Torker/3950Lbs"
Old 06-25-2003, 05:37 AM
SCOTT ESTERLE's Avatar
SCOTT ESTERLE SCOTT ESTERLE is offline
Possibly it was just a bad module it can happen. Replace it under Warranty & re-install & you should be ready to go. We sell tons of these things with very few problems like others have said.
Old 06-25-2003, 06:08 AM
Mike Davis's Avatar
Put on in my fathers 67 GTO 4 years ago no problem. I know of a couple guys that had problems due to the ring rubbing the pickup.
65 GTO, Tiger Gold, Nostalgia Super Stock 421, 2-Carter AFB carbs, Stock Suspension, 3550lbs Full Exhaust-- 9.70's@135
66 GTO (Retired race car)
421 CID
66 GTO 389 3x2, 4 speed, 3.90 gear, Montero Red 33K original Miles
Old 06-25-2003, 06:26 AM
David Jones's Avatar
I have the Pertronix HEI. It has worked great for about 4000 miles.
http://kurtspontiac.homestead.com/DavidJones69GTO.html
Old 06-25-2003, 07:06 AM
tom s tom s is offline
I have one in both my tempests,also my RA V T/A.I guess I have been lucky.Tom
Old 06-25-2003, 08:03 AM
Injunjoe Injunjoe is offline
I have had a Pertronix module in my Firebird for 6 years. The car has made over 300 passes down the 1/8th mile and has over 30,000 miles on the street. I have had direct coil voltage arcing to the negative terminal of the module when a coil went bad and the module still works perfectly. Sounds like you got hold of a bad module. Glad things are going well for you though, I know how it feels to not be able to drive.
Joe
Old 06-25-2003, 06:28 PM
Never Enough Power Never Enough Power is offline
Have installed and sold a number of Petronix units on many brands of cars and have had no complaints about the unit and NO come backs.
Old 06-25-2003, 10:00 PM
Jon Wood Jon Wood is offline
Petronix has worked GREAT for me. I solved all of my car's electrical problems!
Old 06-25-2003, 10:28 PM
Bud Lyons's Avatar
Bud Lyons Bud Lyons is offline
Send a message via MSN to Bud Lyons
I tried putting one on my Sunbird. Damn thing wouldn't fire. I was on the phone with their Tech trouble shooting it for some time. Bad module!
Dropped in an HEI and fired right up.
My Rig's a little old, but that don't mean she's slow.
WWW.PatriotGuard.org
Standing for those that stood for us.
Only two defining forces have ever offered their life for you, Jesus Christ and the American G.I.
One for your soul; the other for your freedom
Old 06-26-2003, 02:42 AM
Well Iam glad all or most of you had good luck, its so frustrating when something like that does not work and causes a bunch of grief. I was worried I was going to lose another summer. Anyway, I called summit racing and they are more than happy to warrenty it for me, those guys at summit are very professional, glad I got so many responses.
Old 06-26-2003, 05:34 AM
Lloyd-TX's Avatar
Lloyd-TX Lloyd-TX is offline
Yeah, I realize that the Pertronix has been out longer, but the Hall effect design and stock external appearance (single wire to the negative side of the coil - just like points!) of the T.I. Specialties/M&H system is the way to go. PY sells 'em for $139.
I'm NOT dissing the Pertronix, heck I've never used it. But, using this system and a stock Delco coil, my Formula lights off at the first twist of the key EVERY time. Went 12.96 @ 104 on my 10th pass with the new engine! Gapped my R43TS plugs @ .040" BTW.
Just my .02 worth!
Lloyd
'72 Formula 455 - TH400, 3.08 posi, A/C, Y99 suspension, tach & gauges, AM-FM stereo, 8-track, Formula steering wheel, etc.; Lucerne Blue with Medium Blue deluxe Interior; 12.96 @ 104 MPH @ the '03 PSN's
Someday I'll be restoring a '72 GTO 455HO, TH400, A/C, etc.; Sundance Orange with Parchment buckets
Regards,
"455HO" Lloyd
Old 06-26-2003, 07:48 PM
momo ´70 formula momo ´70 formula is offline
I installed a pertronix in my stock points distributor. Just set it up properly and you won't have any problems unless there is something wrong with the module.... which could happen to any electronic module.
Find out what the problem is before dissing a product.
Old 06-28-2003, 10:13 AM
428GTO70's Avatar
428GTO70 428GTO70 is offline
Send a message via MSN to 428GTO70
I just dropped in a pertronix flamethrower hei and it works great so far also.
GR-RRR!
1970 GTO 458 CID .040 over 4 Bolt 428 Block, Forged Eagle 455 Crank, 295 CFM SD KRE D-Ports, SD Old Faithful HR Cam + Comp HR Lifters, PPR Maxx-lite rods, Racetec pistons, PRW 1.65 SS Rockers, 900CFM Holley HP TBI, Performer RPM, Hooker Super Comps, 3" X-Pipe into 2.5" mufflers/tailpipes, 2.75 1st TH400, Continental 13" Converter, 8.5" 3.08 Posi.
Everything installed, fired up and tuning has begun!
Old 06-29-2003, 04:53 PM
74gto's Avatar
74gto 74gto is offline
I have used pertronix for years. YOU MUST CHECK THE RESISTANCE OF YOUR COIL!!! If you don'nt have at least 1.5 ohms resistance, you must put a ballast resister in line. Doublecheck with pertronix on that figure i gave above. Also, make sure you have a good 12V source for the Pertronix. Do'nt use the original point wire as the resister in line will drop the voltage to 8-9 volts after the car starts!!
74 GTO 406 T400
74 Firebird 350 4-speed
68 GTO Convertible 400 T400
76 GP LJ 400 4BBL T400
78 Chevy 1/2 Ton Truck
74 GTO 406 T400
Oh yea I love my wife very much
For some reason it got erased when I put it here last time!!!!!! hmmmmmmmm
Old 06-30-2003, 07:00 PM
tonysgoat tonysgoat is offline
Ditto on trashing. My 66 GTO NEVER EVER ran better! Ask anyone who knows, really knows engines......points suck! After 4,000 rpm points blow! Duh, I knew that in 11th grade....in 1972!
Ever think the module is bad???????????/
1966 GTO
