I have a new to me 78. Bought it off a buddy. He is the 2nd owner. He did not know much about it. GUy before him did all the work!
Anyways, How can I tell if it is a WS6/7? The Engine has been re-done 2 times. Beautiful car. White with Red/Black/Charcoal Graphics. Says 6.6 T/A on The Shaker. Not factory Rims, but the 26 year old T-tops are still in great shape. Not much body damage. Few key marks, and one spot of rust! Just have to hop on the brakes and the carb. Brakes seem to have a bad vacum line. I hope that is all it is!!! Thanks in advance everyone! |
You can tell if its a real TA 6.6 by the 2 letter engine code next to the timing cover. Should also have 6X-4 heads. 4 is stamped on boss behind A/C bracket bosses near the valve cover.
WS6 used white nylon sway bar bushings at the front sway bar ends to the control arms. Also a larger rear bar. Measure the rear bar diameter.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
u can also check if its a true 6.6 TA if it is four speed..only four speed cars came with dat engine out of the factory, engine code Z.
Engine code is Z. That's for sure.
It is an Automatic. It had the Hurst Dual Gate Shifter. Not sure if that was stock or not. DId they make Auto WS6's? |
You could get the 220 hores motor with the auto in 78, with or w/out the ws6 option. I don't think the used the nylon front sway bar bushings till 79. The only way to know if it's a ws6 car is to find the build sheet on the car. The sway bars could have been changed over the last 26 years. Good luck
AS far as the W6 If U look at the tire data on the drivers door and it reads a metric # 215R70 15 it's a WS6. if D/15 it's not. Sounds like mine. Just about all my vac lines where bad ,cracked ends splits whatever, also the gaskets in the carbuator had shunk so all the bolt(screws) holding it together where loose , after tightening it was all that was needed. Happy burnouts
JIM |
http://www.christransam78.com/ |
Thanks for the info guys. Can't read the tire data door. Will try phs.
Thanks |
Hard to beat PHS. WS6 was a suspension option including 8" honeycombs, larger rear sway bar, different rear spring front eye busings. Different nylon front bushings and a different steering box that was a fixed ratio not variable.
Until about March 1978 you could get the auto with a 220 hp motor , after that just with a 4 speed. I missed out by 1 month! Also the car was NOT shipped with the WS6 as ordered. Took it anyway as I couldn't wait another 3 months. Stil in the garage!
I think the WS7 option appeared in 79 when GM started using 4 wheel disk on the WS6 package, & then they ran out of rear ends. So they slapped drums back in those WS6 cars & called it WS7. I read that somewhere........
W72 auto cars should have a X7 block code. YA, or YU for standard L78 400
![]() 68 GTO 4-spd Convertible 78 S/E Trans am L78, WS6 Auto 78 S/E Trans am W72, WS6 Auto 79 10th aniv W72 Trans am 80 Indy pace car Trans am 89 Trans am GTA |
