Old 06-21-2004, 11:23 PM
JBurnz400 JBurnz400 is offline
Need some help choosing a good Cam
My Plans are to keep the motor in lower RPM range, do to stock Rod Bolts, i dont really know there limit.
400ci w/ compression somewhere just over 8.1:1
th350
3.08 Rear, which i plan to bump up to 3.23 or little higher
P295/50R15 Tires
the cam i was thinking of getting is the Crane Powermax H-272-2 which has a Adv of 272/284
Any suggestions are greatly apreciated!!
th350
P295/50R15 Tires
Old 06-22-2004, 04:00 AM
David Jones's Avatar
I have that cam in my 400. It has #48 heads, with somewhat more compression than yours though. Nearly smooth idle and good vacuum for power stuff.
Old 06-22-2004, 06:25 PM
Z Code 400 Z Code 400 is offline
Or Summit's K2801 would also be a good choice...Robert
Old 06-24-2004, 08:04 PM
JJake JJake is offline
Look at a Comp XE262, works good w/low compression, good idle, no flat spots in power up to 4800rpm, works good in my 79 TA 400 4spd, 3.23.
Old 06-24-2004, 08:11 PM
Crower 60240
270/276 advertised
210/221 @ .050, .422/.446" lift.
