What engine is the E code for a 75 Formula? Thanks.
I do not believe there is an E engine code for your year of formula ? Have you double checked the serial plate in the winshield ?
---------------------------- 74 pontiac firebird formula 400 |
That's where it got it. Here's a shot. It's all I've got. The door was locked so I couldn't do better. It looks like an E to me.
A negative. I'm sure it was an E by looking at it in person.
$1000 car.
i have the same code "E" on my formula. this is a V8 350 4 BBL
nvm then theres your answer and ive learned some thing new ! Just ive never seen that tho ive never looked at a 75 formula with a 350 so there yeah go !
Okay, thanks. I guess in 75 it would be a Pontiac V8 and not a Chevy?
Yep. I believe the last year for all Pontiac derived V8's was 1976. In '77 GM started using Olds and Chebbie V8's on anything less than 400 cu. in. with the exception of the Pontiac 301.
1971 Trans Am 455 H.O. - Cameo white 1982 Recaro T/A 305 - Black |
yes Dennis Smith, you're wright.
76 was the last year for all PONTIAC engine. in 77, the 305 chevy came. the 350 and 403 olds too. 301, 350 and two 400 PONTIAC engine stayed. |
This car no longer has a Pontiac in it. The sheet of paper says 1983 305 HO. Woooooo. An HO 305, wow. It also says it's a 75 Trans Am with limited slip. It doesn't have an limited slip tag on it though.
What's wrong with the front of this car. Is that a 75 bumper cover with a 76 nose? Or is it a 74 nose and 75 bumper cover? |
Doug, that's a stock 75 nose and bumper. It's missing the filler strip that goes between the bumper and nose. They tended to deteriorate over the years. They're still available from GM and can be found all of the time on Ebay for around $80. The car doesn't look bad from the pictures you've posted, especially for $1000.
Love Those Formula Frontend, I would buy it for a 1,000 and replace the motor
74 Formula Below motor destroyed last fall 469, 6X-4's, 72 Intake, Ramair Manifolds. 3 inch exhaust with x-pipe Custom Roller Cam, 1.52 Roller Rockers Quadrajet done by Cliff 3:42 gears 12.061 @ 110.74 12.092 @ 112.43 12.128 @ 111.71 New motor 461 stroker Edelbrock 87 cc dport heads Performer RPM Same Ram Air manifolds, and quadrajet Results will be posted after the track |
The car has waves and repairs in it, but I've seen worse. That looks SOOO much better with the filler piece in it. Very nice car. What's the deal with the park lights in the grill though? I'd sa the car could be had for less. But's butchered under the hood. Auto car, A/C is hosed badly. Here's the seats in it. They aren't as good as they look. The only options I saw was a tach and a/c.
In 1975 the turn signals were moved to the grills and some "fillers" installed where the signals were in 1974. This was also the first year for the wrap-around rear window.
The seats look like they are recovered 1970 Firebird or Camaro. Probably get a couple hundred bux right there ...
Yeah definately not a bad deal for 1 grand i got my 74 formula for 800 bucks but engine is in bad shape so and interior was not that great but the body was in perfect condition
