Old 07-28-2004, 06:32 AM
crkoester's Avatar
crkoester crkoester is offline
I'm sure this has been asked many times before, but the search feature is not working at all.
Will a Pontiac clutch housing and flywheel bolt directly up to a 350 small block Chevy? If not, is there a kit or do you need to use Chevy parts?
Chris
69 GTO Hardtop project - started without a clue, will finish only by the grace of the PY Forums and Mr. Dave Wrzesinski (magicV8) - candidate for Father-In-Law Of The Century.
We are building a bad-ass, hot-looking, hot-running Pontiac street machine.
crkoester's Avatar
Chris
Old 07-28-2004, 08:29 AM
nova385 nova385 is offline
no- the bell housing will not bolt up - the pontiac flywheel will not go on a chevy- not sure about the adaptor.
Old 07-28-2004, 09:25 PM
Thumpin455_GTO's Avatar
Thumpin455_GTO Thumpin455_GTO is offline
All the larger Pontiacs had 11" clutches, the only SBC to have them was in trucks. Everything else is different, you wont be able to use anything other than the throwout bearing and the transmission itself.
