Old 12-31-2004, 04:59 PM
dottrz dottrz is offline
I am installing a 428 into a 77 TA. Will my shaker match up correctly? I will be contacting Nunzi's for his set of mounts, so I am concerned that the offset might affect how the carb matches up with the shaker. Thanks!
The Ott'r
Don Ott
The Ott'r
Don Ott
Old 01-01-2005, 03:58 AM
RAJNWDY's Avatar
RAJNWDY RAJNWDY is offline
if you are going from Pontiac engine to Pontiac engine it will be the same, unless you go with a aftermarket manifold like a Victor or RPM. They sit taller on the engine and you will have hood clearance problems. If you have a Old's 403, the hole offset for the carb and bottom can are differant and they take a differant scoop which sit's lower in the hood.
Happy New Year
RDRR Custom Fabrications
....A fictitious company doing fictitious work....
Old 01-02-2005, 06:06 PM
I will be using a Performer RPM intake, and will be seeking one of the aftermarket kits to make it fit under the hood. (I also want to use a functional "flapper" on the intake of the scoop.) I was kinda concerned that the engine would be too far forward to allow the shaker to fit through the hole as it sits on the carb.
Don Ott
Old 01-02-2005, 07:44 PM
Larry Navarro's Avatar
If you use the '77 or later scoop then the assembly I offer will work with the flapper kit you plan to use.
Don't worry about offset as the WFO assembly can be adjusted in any direction off-center up to 1".
I doubt that there will be any need for this.
