I'm at a loss. I installed a holley blue electric fuel pump on my engine along with a high torque starter. The starter cranks the motor with no problems, so that's just fine
I would suspect 1'st that you have something stuck in the needle and set.
1'st try tapping (lightly with a screwdriver handle) on the side of the carb while the pump is running to see if it unseats the oject holding the needle off it's seat. If not, I'd take the top of the carb's body apart and see what is keeping the needle from seating after the float closes it. I'm sure the others will have more suggestions, but that's my take on it. Best of luck. Steve. http://photo.starblvd.net/zanko20 Can you hear me now?
https://www.flickr.com/photos/197745168@N07/ "There's nothing more unsatisfying than watching an electric car go down the dragstrip." |
It has to be something stuck in the needle and seat. Teflon tape or a bit of rubber from the new hoses perhaps..... Pulling the carb top is the only real sure way to clear out something in the needle and seat.
Big block? Small Block? Nope, It's a Pontiac Engine!
