Old 01-08-2005, 09:23 AM
mwritter's Avatar
mwritter mwritter is offline
I have a complete PB system for my '65 GTO that I swiped from a '72 Monte Carlo in the junk yard. Simple question: will the booster clear the hood/inner fender on my '65? Or will I need a smaller booster? I have read conflicting opinions on this, and I'd rather know before I get the whole car torn apart. Thanks for the help.
Matt
1962 Grand Prix - Cameo Ivory|389 4sp|One-Owner Survivor
1964 GTO HT - Silvermist Grey|389 3x2s 4spd|A/C|Hurst Wheels|Frame-off|SOLD
1965 GTO Post - Mayfair Maize|421 3x2s TKO600|Pro-Touring|
1966 GTO HT - Barrier Blue|389 3x2s 4spd|Red Fenderliners
2005 GTO Coupe - Yellow Jacket|Magnacharged LS2 6sp|543hp/561tq|SOLD
2006 GTO Coupe - Spice Red|LS2 6sp|20k orig miles
mwritter's Avatar
Matt
Old 01-11-2005, 11:32 AM
miketgto miketgto is offline
did this conversion on my 65. used original style 9 inch booster.later will not clear 65 inner fender they put a crease in later model inner fender to clear booster. you could massage it.
Old 01-11-2005, 11:55 AM
mwritter's Avatar
That is exactly what I was afraid of. I suppose I should price a new booster, as mine is used anyway. I would hate to ruin a perfectly nice inner fender.
Matt
Old 01-12-2005, 09:36 AM
RayJ RayJ is offline
I did the same using a '71 Monte Carlo system for my '64. I purchased a used smaller power booster for $35 and had it rebuilt and plated. There are at least two different length rods that come out of the booster and attach to the brake pedal depending on car model and year. If I remember correctly, I had to change out the rod on the used 9" booster. Check this out before restoring the booster.
Old 01-13-2005, 02:17 PM
mwritter's Avatar
Great info...thanks. One more question for RayJ, MikeT3x2, or whomever. I have located a 9" booster, will my '72 Monte master cylinder bolt up? Or am I looking at a new master as well?
Matt
Old 01-13-2005, 04:22 PM
If I remember correctly, I purchased a rebuilt '71 and it bolted up OK. It is pretty big compared to the 64-65, but it worked. I found that the rebuild kit was as much as a unit already rebuilt, so I bought the rebuilt one. If you do get a rebuilt one, ask to look through the ones they have in stock and pick out the best cover. There seemed to be quite a difference in the plating quality. I painted my master cylinder exterior with Martin Senour cast iron gray and it continues to look great.
