Old 06-13-2004, 09:14 AM
nosliw nosliw is offline
sounds really expensive to me, but banging through the gears with a freshly built 455 would be worth it.
is there like an article i can read that will have step by step what i've got to do? i'm sure i'm not the first to want to do this. how about getting the equipment? i know i can't find anything at a junk yard- i've looked. this is a new idea which i haven't really thought through so any point into the right direction would be appreciated.
thanks
thanks
Old 06-13-2004, 09:20 AM
android 211 android 211 is offline
If you have a '68-'72 GTO you're in luck, OPG sells clutch linkage kits consisting of NOS and repop parts - complete. Finding a good Muncie isn't too hard on the internet. Buy a new bellhousing, clutch, shifter and flywheel. Lots of people sell four speed pedal setups on eBay. Get the factory manual and enlist the help of a good transmission shop. Its worth it - you'll substantially increase the value of your car. If you have a pre'68 vehicle you'll have a hard parts hunt for the clutch linkage but it's not impossible. Hydraulic clutch linkages are also a possibility.
Old 06-13-2004, 09:24 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by robocop:
Hydraulic clutch linkages are also a possibility. <HR></BLOCKQUOTE>
but don't i have to do a lot of fabrication on the chasis for that? i think i was watching the show "trucks" when they did that but it was a while ago...
it's a 67 tempest. sorry, i'm kind of a newbie at this, but Muncie is the manufacturor of the actual transmission itself?
Old 06-13-2004, 09:50 AM
tom s tom s is offline
hyd clutches are easy but not cheap.Tom
Old 06-13-2004, 11:04 AM
erikgto's Avatar
erikgto erikgto is offline
I thought that hydraulic clutches weren't available for these cars.
I own a '68 GTO 4 speed and I can't seem to get used to the heavy mechanical operation of the clutch. It is the one thing I really don't like about my car. What's needed to convert it to a hydraulic setup......
'67 GTO hardtop coupe 400 2bbl (sporting a 4 bbl)
'70 GTO convertible 400/400, matching numbers, Currently getting worked on again, body in the bodyshop, engine at the machine shop etc!!)
'71 LeMans Sport T41 Coupe restomod (GTO clone with Judge stripes and wing) 400/350
'71 LeMans Woody Wagon 400/350 patina project
1975 Grand Am 400 factory sunroof project car
Old 06-13-2004, 08:12 PM
hyd clutch is not easyer to pushin,it just get rid of the linkage.You mount a M/C on the firewall,the rod goes to it from the cluth pedal.You use a expandable hyd throwout bearing on the nose of the trans,a hyd line goes from it to the M/C.No fork or any mech. linkage at all.Tom
Old 06-13-2004, 09:30 PM
6D6GOAT's Avatar
6D6GOAT 6D6GOAT is offline
i bought a set up on ebay to convert my 350TH to a 4 speed in my 66 lemans. i think you could probably buy all the parts you need out of catalogs but i think that would get pretty expensive. a couple of things to remeber.. i had to remove the drivers side front fender so i could weld the little bracket to the frame for the z-bar and i had to do some floorboard modifications for the shifter and firewall modifications for the clutch linkage. the original crossmember and the drive shaft didnt need any mods. also, if you are running headers you will probably find that the clutch z bar will hit it. alot of headers claim that they will work on 4 speeds but the only one i could find that would work were the hooker super comps. hope that helps, you can e mail me direct for more details of you like. [email protected]
and yes, it was worth all the trouble to be able to bang through the gears with a 4 speed.
Vic in SoCal. Follow me on Instagram- Cloud9orbust
66 GTO clone, 467 cubic inches of Turbocharged Multiport Fuel Injected fury twisting a TH400 into 3.90's wrapped in a 12 bolt posi.
My T56 Install
My Turbo Build
My Vortech Supercharger Build
Hyd Throw out bearing
Misc Build Pics
May the Karma Gods meet you half way....
Old 06-15-2004, 09:09 AM
GS470 GS470 is offline
I converted my '72 LeMans from an auto to a manual last summer. Yeah, it was some work and took a couple bucks, but it is so much fun to run through the gears now.
Even though I installed a 5spd, I still installed a mechanical clutch (Centerforce DF) and Lakewood scattershield that are the same exact components used for 4spd cars. I bought most of the parts I needed to do the conversion from Performance Years (the company that sponsors this forum). PY didn't have the pedals I needed, but I think they offer a set that would fit your car along with just about all the other linkage you'll need.
I've got D-port heads on my car and run Doug's headers and have no clutch linkage clearance issues.
Good luck!
'72 LeMans 2Dr Hardtop
My first car, purchased in 1980
468 Stroker / KRE 315 / HR cam by SD Performance, Tremec TKO II 5spd
'96 Corvette Grand Sport (#470 of 1000 built)
Mildly modded LT4, 6spd
'07 Corvette Z06
Mildly modded LS7, 6spd
'67 Chevelle Convertible
LS6 (405HP Z06), 700R4
Old 07-19-2004, 02:11 PM
Hulaman Hulaman is offline
Ditto to Robocop above. I converted my 71 gto
to a muncie m-20 wide ratio over the winter
and attention to detail is a must, especially
when it comes to the clutch linkage. The Pontiac
Restoration Guide 1964-1972 was a great help
along with all the advice from this site. Your right, there's just something about throwin' 4
gears around listening to a good ole 60-70ish
oldie but goodie on a sunny afternoon. There's a song in that somewhere.
Good Luck
Good Luck
