Old 05-24-2003, 03:02 PM
doug64cutty doug64cutty is offline
I can't seem to find the help i need on olds boards and I was told that Pontiac and olds posi rear ends were the same for a-bodies 64-66. I was given a 66 442 posi rear with 3:90 gears. It has a 4 pinion posi (unusual i think). Unfortunatly it has a chipped pinion. I'd really like to get into some 3:42's or 3:55's.
Will this carrier work with other gear sets?
Are gear sets available for these years?
64 cutlass
66 vista
64 cutlass
66 vista
64 cutlass
66 vista
64 cutlass
66 vista
Old 05-24-2003, 06:48 PM
The '66 Olds 442 used the 8.2 BOP (64-66) 8.2 10 bolt ring & pinion.
One can buy the following new Richmond gear series from Summit (243.95+ ship) or California Gear:
-3.55
-3.90
-4.10
-4.56 (maybe still avail)
Select used (or impossible to find nos) gears to fit same low ratio 8.2 10 bolt carrier are avail in following ratios:
-3.36
-4.33
The 3.42 gear ratio was not used with '64-66 BO or 64-69 Pontiac 8.2 ten bolt, but was a '68-70 Buick 8.2 10 bolt...will not fit anything but 68-70 Buick 8.2 hsgs.
Old 05-24-2003, 09:49 PM
thanks a ton,
also are there any tricks to setting up these (64-66) rears? I mean compared to the gear swap on a corporate 10 bolt. Thanks
64 cutlass
66 vista
64 cutlass
66 vista
Old 05-25-2003, 03:55 PM
Kenth's Avatar
Kenth Kenth is offline
Check out www.442.com,you will have all information needed.
Buick and Pontiac shared the internals 64-67,Olds were using these axles these years.1968-70 Olds had their own 10-bolt 8.3" wich had a 12-bolt cover.Buick went to 8.5" ring 1968 and Pontiac continued with the 8.2" to 1972.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
