Old 01-25-2002, 02:48 PM
Kurt Vinje Kurt Vinje is offline
Could someone help me out on this topic?
Will a 1967 tilt column fit without a problem in my 1966 GTO
Old 01-25-2002, 03:11 PM
Ccass's Avatar
Ccass Ccass is offline
Administrator
Kurt, The little collar that mounts just below and into the dash is different from 66 to 67. Also, you need to consider the type of steering wheel you want to use. 66 and older wheels will not match up well with the wider diameter 67 steering column. Other issues; column wiring to dash wiring is different. I wouldn't recommend it unless you've thought out these obstacles.
Old 01-25-2002, 05:12 PM
Thanks! Sounds like trouble to me. Ill keep looking for a 66 Tilt Column
Old 01-28-2002, 05:06 PM
goatang goatang is offline
Hey CCass Take that electric thought a little furthur please. I too am changing a 67 floor shift column into a 66 gto I can put column into lower dash "seat" and use a different u-clamp, with a little coaxing. Now I look at wiring and find 6 out of 7 wires match in color. Why can,t I clip ,rematch wires, and then wire them into 66 connector. The only wire that doesn,t match looks to be gray wire which was for shift indicator(no longer necessary). 67 connector has an ,unknown to me, brown wire. Yes it,s some tedious work but not overwhelming. Any thoughts? Thanks
Old 02-03-2002, 10:54 PM
blue67gtoragtop's Avatar
blue67gtoragtop blue67gtoragtop is offline
I you decide not to use the 67 tilt column,I am looking for one. I need auto w/floor shift.
Old 02-04-2002, 12:38 AM
I,m glad to hear you have a tilt column and I suggest you trade it for a 66 tilt column. I just learned more about columns than I wanted to know,but here it is for you. 67 is the same length and would work. CCass is right in that it is a fatter column, but it will "seat" into dash. However the u-clamp won,t work so you have to improvise. I gave up when I saw the electric problems. The c-connectos don,t match(67 is bigger). I think you could snip, match, and splice together,but I thought better of it. I bought correct covers for a 66 and quit. To have a tilt piece I do think you should get the correct one. Good Luck
Old 02-04-2002, 02:13 PM
6567GTO's Avatar
6567GTO 6567GTO is offline
I saved a 67 Catalina tilt column which I thought might work in my 67 GTO. I realise that the Catalina was a column shift so I knew I'd have to redo that part of the column to make it look like it came from a floor shift car. Will this column work in my GTO or should i sell it?
_________________________
Sonny Barger
Old 02-04-2002, 02:37 PM
'67 B-body & A-body tilts are not the same. The B-body column is considerably longer than an A-body for every year it was produced. '67 & later column shift B-body columns contain some good core pieces to use in the building of more desirable columns. To me the '67-68 B series tilts are $75-100 core material max...have bought an obscene amt of them in the last 15 years.
Old 02-04-2002, 06:29 PM
6567GTO's Avatar
Thanks! Anyone looking for a tilt wheel out of a 67 Catalina?
Sonny Barger
Old 02-04-2002, 11:38 PM
Ken K Ken K is offline
The pedal hanger is different on a 67 A body than it is on a 66. You can switch the pedal hanger but you will also need the correct brake and clutch pedals because they are also different. A 68 Gran Prix tilt column can be made to work in a 67 A body, the difference is that an A body has a longer steering shaft. If you match up a 68 Gran Prix tilt column to am early Camaro they are the same length, I would assume it will also work in a early Firebird. A 67 A body tilt column sold recently on Ebay for $710.00.
Old 02-04-2002, 11:55 PM
6567GTO's Avatar
Whoa! Too rich for my blood.
Sonny Barger
Old 02-05-2002, 12:08 AM
Ken,
Good to see you back posting on PY.
Old 02-16-2002, 10:53 PM
Did you decide to use the 67 column? If you would like to sell it- e-mail me [email protected]
