Old 12-30-2002, 07:08 AM
61man 61man is offline
How can you tell if your car is suspossed to have a vented gas cap or not????? [img]/infopop/emoticons/icon_confused.gif[/img] [img]/infopop/emoticons/icon_confused.gif[/img] [img]/infopop/emoticons/icon_redface.gif[/img] [img]/infopop/emoticons/icon_cool.gif[/img] [img]/infopop/emoticons/icon_cool.gif[/img]
http://kurtspontiac.homestead.com/Pre1964Pontiacs.html
Old 12-31-2002, 01:54 PM
I guess nobody knows
Old 12-31-2002, 02:37 PM
sygto sygto is offline
No vented cap required ...if.... you have a vented
gas tank neck or vent from top of tank to fuel pump (I think this is on AC cars only) You have to vent somehow, somewhere!
Old 01-01-2003, 07:33 AM
Michael Farich Michael Farich is offline
IIRC, GM A and B bodies got external fuel tank vent gadgets behind the rear seats in about '71 or '72. Prior to that, a vented cap was used.
Old 01-01-2003, 09:08 AM
78 GHOST 78 GHOST is offline
61Man, I don't know the arrangement on early cars. But, on my 70 GTO, it has two vents. One is about 2" below the cap and originally used a small section of hose to attach to a small diameter "U" shaped section of metal tubing mounted so the top of the "U" was at the top. The "U" section was mounted in a rubber plug/grommet which was located just to the left of the trunk latch. These "U" shaped sections of tubing are hard to find and frequently rusted or plugged beyond all repair. Currently, I'm simply using a section of fuel line to accomplish the same effect until I can find a good "U" section.
The other vent is toward the front of the tank and is a section of rubber tubing with a small fuelproof filter at the end. The "filter" only serves to keep insects and other foreign debris from entering the tank and getting into the fuel lines.
____________________________________
It was a hot summer night. Slowly I spread her legs and my hand was trying to find it's way to her nipple... I was so excited! I never milked a cow before...
"I work in high speed aluminum tubing."
Old 01-06-2003, 08:05 AM
GDK_1968 GDK_1968 is offline
I asked the same question some time ago and also did not receive an answer, but...
My '69 has the same inverted "U" set-up as decribed by 78 GHOST, not left of the trunk latch but within the confines of it. I went on the assumption this was for venting, so will be buying a non-vented cap.
1969 GTO Restoration
