Old 04-30-2002, 09:47 PM
JEFF KING's Avatar
JEFF KING JEFF KING is offline
installed msd box 2-years ago worked great!
now i can,t shut off my engine in my 69-gto.
i checked everything!it,s got to be the box.
what gives?
"And he Asked, Who Owns This Car? With The Peace Sign, Mag Wheels, and the Four on the Floor??
JEFF KING's Avatar
what gives?
Old 04-30-2002, 09:52 PM
berrygoat's Avatar
berrygoat berrygoat is offline
Did you install the diode in the alternator harness ? I had the same problem with my 69 but it was with initial start up after box installation.
Old 05-01-2002, 12:51 AM
Colorado Bill Colorado Bill is offline
As Berrygoat said, did you install the diode? I had the same problem with an MSD on a '70 GP. There is a diode that I think comes with the MSD-- you need to splice it into one of the wires coming off the voltage regulator. I think terminal 4, but it's been a long time so I'm not sure. Call MSD tech if the instructions don't help.
Old 05-01-2002, 12:52 AM
**Dang double post gremlins.**
[ May 01, 2002, 08:57 PM: Message edited by: Colorado Bill ]
Old 05-01-2002, 02:09 AM
ponchopete ponchopete is offline
Just so you know, in case you don't have the correct diode, it takes a 1V/100A diode. You can pick these up at any Radio Shack.
"Q: What's better than winning a gold medal in the Special Olympics? A: Not being retarded."
Old 05-01-2002, 03:06 PM
Half-Inch Stud's Avatar
part number is 1N4001.
I would use the 1N4004 for ruggedness.
H.I. Stud
12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct
