Old 03-05-2003, 11:12 AM
willy willy is offline
Hi, i am a first time user to your site.
I have recently fitted a working hood tacho
only to find it came off a 6 cyl firebird
sprint. Can I make it read correctly fitted
on my 8 cyl 400 ?
It is an old original tacho not a repro. Any
help would be appreciated.
on my 8 cyl 400 ?
Old 03-07-2003, 02:34 PM
cuz68's Avatar
cuz68 cuz68 is offline
Will work the same way on 6cyl or v8.
Cuz68
Old 03-07-2003, 05:56 PM
Jack Blum's Avatar
Jack Blum Jack Blum is offline
Actually it won’t work . These old tach’s use the points wire to pull the tach signal to ground giving the tach 1 pulse each time the points close. The pulses keep a RC (Resistance/Capacitance) circuit charged, the frequency at which the pulses come in increase the charge on the RC circuit. Think of the RC circuit as a funnel, the faster you pour in water; the higher the level in the funnel goes up. The charge is then used to set the meter, or the dial you see. So the tach is expecting 6 pulses per revolution of the distributor, and if you hook it to a V8, it is now getting 8 pulses per rev. Thus it is probably reading to high. You may be able to modify the circuit boards RC components if you can get the internal schematic for a V8 tach. I remember seeing on this board a post for a web site that has the schematic.
TigerEFI.com (Classic Pontiac Fuel Injection) [email protected]
Motto: Build it for NASA and drive it like you stole it!
2004 GTO Company car, 1994 TA 25th Anv, 1971 Grand Safari Wagon, 1968 GTO EFI, 1968 GTO Stock, 1968 GTO Convertible in desperate need of restoration.
