Old 07-19-2000, 08:07 PM
Tomo Tomo is offline
I am installing a 1970 455 into my 1964 GTO.
The vendor sent me motor mounts for a 455.
They look like the wrong mounts to me. They
look like they would move the motor about 2"
foward.Presently I have a 400 in it and the pins are too short to span these new mounts. The vendor said to use mounts for the motor not the body.
What mounts do I need. thanks
tom
tom
Old 07-20-2000, 12:18 AM
Rocco Testa's Avatar
Rocco Testa Rocco Testa is offline
The 455 will bolt right in. Your block should have 3 holes & not the two like the early blocks have. Just move the mount. If you still have a problem you can call Nuniz. He was the first guy to make special mounts for the late year motors. But I think this would only be a problem if it were a Firebird. Nuniz Auto (718) 837-1135 tek after 5 pm. There also may be a link on the web to his web site. I also think Perforance Years sells the motor mounts if you need them.
Old 07-20-2000, 12:33 AM
Todd Todd is offline
Always, Always, Always use the mounts for the CAR, not for the engine!!!
Your 64 GTO (assuming it had a Pontiac V-8 in it and was not subject to a chev engine swap) will have the correct frame mounts.
Your 70 455 block will have 5 motor mount holes per side. The two lower rear are for the 64-73+ A-body mounts (along with most other Pontiac models of that vintage).
The 3 forward holes are for the 70-81 Bird mounts which are different than all the rest (and some others in the late 70's, we'll discuss them below).
If your old rubber motor mounts from your GTO are in good shape, just re-use them. If you want new ones, they are available at any local parts store (ask for 64-72 Lemans V-8 mounts) for about $12 each. There is a left and a right mount (bolts that attach the frame mounts to the frame brackets go through from the FRONT).
Starting around 74, Pontiac re-designed the engine mounts so that the rubber part of the mount was in the frame bracket and the part of the mount on the engine was a solid steel piece of metal. Add in that Full size sometimes used a diff mount (and we already know the 70-81 Birds are diff) and you can see why you ALWAYS need to use the mounts for your car.
Last thing: Find another vender for parts or at least QUIT asking that particular one for advice since it's obvious they don't know Pontiacs.
Old 07-20-2000, 09:13 AM
Thanks for the quick response. Just received a RMA to send these mounts back. As far as the vendor is concerned I have spent over
$2000 with them over the past 5 years and will continue to buy from them for they are a pleasure to deal with. Considering on where I am posting this they are NEAR and dear to all our hearts.
tom
