Pontiac Business Entities Exchange Sources, Compliments and Grievances in regard to Pontiac parts or services rendered by an individual or business.
Old 04-26-2005, 09:42 AM
Pontiac Performance Author
I'm done with them.The last 5 sets of rods were not right in some way or another. The last set had to be sent back because 2 of the rods were ten grams light.The replacement set had a tight pin fit (the pin would not go in!)and there was a 4-5 tenths taper across the big end bore AND the big end was 7-8 tenths tight @ the parting line.Using Eagle's rod bolt stretch gauge(a nice simple item BTW)i determined the rods were not torqued up to spec when machined @ Eagle.The Crank for the same project had to have the thrust faces polished and the seal surface polished and the rod juornals were 4 tenths thinner in the center than the sides.Two of the main journals were off center by .002" and the crank had to be ground .010"to get it straight.My crank grinder says it's virtually impossible to grind only two journals off center but there they were!
Old 04-26-2005, 10:14 AM
dammen8's Avatar
dammen8 dammen8 is offline
Ken do you remember which 2 mains they were?
Chad
3500lb 10.5" tire. [email protected] with a poor 60'
Old 04-27-2005, 09:17 AM
harry k's Avatar
harry k harry k is offline
Send a message via AIM to harry k Send a message via MSN to harry k Send a message via Yahoo to harry k
I beams or H beams ?
someone who thinks logically is a nice contrast to the real world.
http://www.youtube.com/watch?v=3FfKVVZW1-Y
Old 04-27-2005, 03:11 PM
pontiac6269's Avatar
pontiac6269 pontiac6269 is offline
Not Eagles, but my Scat steel H beams had to have the small end opened up to get the pins in.
Eric
1969 GTO - 461, turbo 400, Continental 13", 3.08 gears. - 12.59 e.t. @ 108.43 mph, 1.898 60'
1978 Oldsmobile Cutlass Supreme- 461, turbo 350, PTC 3500 converter, 9" 3:50 gears. = 11.39 e.t. @ 117.55 mph, 1.599 60' on E85
Old 04-28-2005, 08:51 AM
Bruce Meyer's Avatar
Bruce Meyer Bruce Meyer is offline
Chineese parts = JUNK. Especially the cranks. Ive seen more guys in my area ruin good motors by putting in those junk cranks than I care to know. Yet people still buy them.
Smilies are Off
