looking for some input on carb for my 67, 326. 2 or 4 barrel and intake? the engine has been rebuilt and is running with the original. the car is mostly original and is a convertible. thanks!
Doug, some additional information would make this an easier question. Is your original a two or four barrel? Do you have auto trans or standard? Is the car air-conditioned (other than putting down the top)? Was the engine rebuilt to a reasonably stock configuration? What criteria are you looking for ie. looks? performance? economy? Is your original running poorly, and you need to change, or do you just wish to change? Will try to help if you post answers to above. Jon.
------------------ Good carburetion is fuelish hot air.
"Good carburetion is fuelish hot air". "The most expensive carburetor is the wrong one given to you by your neighbor". If you truly believe that "one size fits all" try walking a mile in your spouse's shoes! Owner of The Carburetor Shop, LLC (of Missouri). Current caretaker of the remains of Stromberg Caburetor, and custodian of the existing Carter and Kingston carburetor drawings. |
the car is an auto trans, it was original with a two barrel. the rebuild was close to stock, a light cam(i dont know the lift). the car runs ok but not as smoth as i like. a little more power would be nice.
also no a/c. thanks for your help!
Doug, probably the easiest (and maybe best) avenue would be to obtain a factory Q-Jet intake from a 1968 or 1969 400 Catalina along with the carb 7028262 (1968) or 7029262 (1969), and the air cleaner. The 1969 especially should be readily available in the boneyards. PY should have a fuel line for the Catalina which should fit. By going with the factory stuff, everything SHOULD fit without major modifications. You may have to go a size richer on the carb primary jets (smaller engine, less volume of air meaning less velocity, and possible lean condition), but I would rebuild it stock first. After you get the engine running, watch your water temperature. If it doesn't run hot, or ping, your mixture will be OK. If is goes run hot, change the primary jets 0.002 larger. There are other avenues (Carter AFB, Holley, etc.), but I would recommend this one for best driveability, and ease of conversion. Jon.
Doug, before doing anything with the carb, find out why the engine is not running smoothly. With the two barrel, should be smooth as silk, but just run out of breath at the top end. Even tho fresh rebuild, check the compression, and ignition systems. The best carburetor ever made won't solve a faulty ignition system. Jon.
