Old 06-11-2005, 09:15 PM
baron_ baron_ is offline
Send a message via AIM to baron_
I posted a while back, thinking i'd blown a head gasket - still think I did.
Got that replaced - no water coming out of the tail pipe or head anymore, so that's good.
But the car's still having the same problem.
I run it for about 10 minutes (sounds great). No movement in radiator at all and coolant still cold. Then, suddenly, it starts boiling and going wild (if cap is off). Thought it was just a head gasket, but i think i blew that from another problem
Put the cap on and it'll squirt out the overflow like mad and you can hear water boiling in the block (a slushing noise). Suddenly, radiator really hot (engine very hot too)
Next i'm thinking water pump, but i turned the fan earlier and i can hear it pumping water (maybe there isn't the proper space as discussed in so many posts?)
(new thermostat, by the way)
Any suggestions? (just stripped a bolt on the water pump and wondering if this should even be my next step?)
It's always something...fix one problem and another comes along
Some pictures for your entertainment...
Clay Marsh
1967 GTO convertible Twin Turbo 5spd project
http://forums.performanceyears.com/f...d.php?t=618281
http://www.youtube.com/watch?v=eJ9KworCMRE
Clay Marsh
Old 06-12-2005, 01:36 AM
Squidward's Avatar
I'd recommend just going ahead with pulling the water pump. You'll be able to get the best snapshot of your cooling system that way. You'll be able to check if your divider plate(s) are in good shape, and you might as well replace your T-stat with another one in case that's an issue. Besides, you never know what a previous owner might've left you with (or without!).
It sounds to me you might not have adequate flow. If your divider plates are corroded away, it can cause the impeller to just spin around, making a whole lot of turbulence and no flow.
Feeling your heater core lines (if connected) can also give indication of flow.
Old 06-12-2005, 09:21 AM
Shadowjack Shadowjack is offline
No water flow, all right. Could be the pump, could be the thermostat. Is the heater hooked up? If the pump is working at all, the hoses will get hot.
BTW, got enough '66='67s?
Old 06-12-2005, 10:07 AM
never enough
i never thought about the hose
i don't have the heater plugged in
i guess i'll just replace the water pump
and cuss at thsoe bolts all day long
Clay Marsh
Old 06-12-2005, 10:21 AM
gtohunter's Avatar
gtohunter gtohunter is offline
Make sure bottom rad hose isn't sucking itself closed, or otherwise blocking inlet flow??
Jimmy M
68 GTO
Old 06-13-2005, 04:35 AM
buwalda buwalda is offline
I would have the coolant system pressure tested to make sure there are no leaks, like a cracked head.
Old 06-13-2005, 08:07 AM
MONTY MONTY is offline
could you also have a air pocket in the motor? That would cause very rapid heating and no flow.
Old 06-13-2005, 09:12 AM
got the water pump off, and there's a ridiculous amount of space between it and the spacer
so i'm putting it back together today and hoping that's it
Clay Marsh
Old 06-13-2005, 09:57 AM
chiphead's Avatar
chiphead chiphead is offline
How many bolts in water pump? Are the '67 timing covers being used? What does the temp gauge say when engine is running?
The 8 bolt pumps used 66-68 require 2 divider plates. The 69-newer 11 bolt pumps require one divider plate.
Check radiator. I had to have my newer 4 core rodded out. The previous engine dumped scale into the cooling system and plugged the radiator. Then I was wondering why my new 400 was getting hot.
Old 06-13-2005, 11:52 AM
SWEETJUDGE's Avatar
SWEETJUDGE SWEETJUDGE is offline
MAKE SURE YOUR NOT AIRBOUND inside the motor
you have to let the engine run awhile & let the coolant burp out of the rad, keep an eye on the temp guage,if theres a lot of burping u have alot of air in the engine
ALSO
try a restrictor instead of the thermostat
there is a blow hole in the water pump i believ if it goes it will piss out the hole
ive had to jack cars up in different configurations to get air out of some motors its a bitch but sounds like your problem
1969 Early 01D JUDGE #s MATCH RA III 4 Spd (Concours Restored)
1969 PRO STREET GTO 2500 lbs. ALL ALUMINUM 505
1969 RARE All Glass GTO (FOR SALE) YOU NEED THIS
AC Cobra Kit Car 521 670 HP/715 Trq
LOOKING FOR V PARTS !!!!!!!!!!!!
Old 06-13-2005, 01:03 PM
If you have an air pocket the thermostat wont open. Remove the thermostat and fill the intake to the top and then replace. Start engine and loosen the temp sender and let the remainder of the air out while filling the radiator. When fluid comes out around sender retighten and continue to fill radiator.
Old 06-13-2005, 05:03 PM
cwolf cwolf is offline
Send a message via Yahoo to cwolf
have you by chance read the post on water pumps in the heating and cooling thread? maybe there is something there to help
Old 06-14-2005, 06:59 AM
dragracer dragracer is offline
before you install the thermostat, if you drill a couple of small holse in the thermostat body, the part that sits against the manifold but still in the water passage, it will let the air escape as you fill it, it works
Old 06-14-2005, 07:24 AM
tininjun67's Avatar
tininjun67 tininjun67 is offline
I'd pressure test the cooling system and then check to see if you've got any coolant in the oil. It does sound like you've got air getting into the system. This is assuming you've bled it and it's full of coolant. If you crack the drain plug on the oil pan a couple hours after the press test and see water before the oil I'd be looking at the head and cylinder wall of the side that blew the gasket. I'd get the head press tested. A stuck t-stat or no coolant near the t-stat would explain the lack of flow. Or a busted impeller on the water pump. I've never been able to spin a pump by hand and see flow in the radiator.
Old 06-14-2005, 07:01 PM
(if you're curious)
looks like it was the water pump
i read the posts about the space between the divider on the 11 bolt...and it was ridiculous
this was a 'new rebuilt' engine by a chebby engine builder noone had been able to get to run right - it was a simple problem all along
replaced with the cast waterpump that has the vanes nearly touching
you can see in the picture, they look half an inch away from the divider...and that's without the gasket (put an old divider on for the picture, so you could see)
thanks for the suggestions
Clay Marsh
