Old 08-17-2002, 11:07 AM
Novice Goat Novice Goat is offline
I am trying to restore a 65 gto, (I'm new at this so be gentle) and was taking off the driverside fender and the bottom nut, closest to the door came loose inside the body. Let me explain because I do not know the name of the panel; the body pannel that runs down between the front and door windows, behind the fender and just in front of the door (seems to be connecting the door jam to the fire wall ), there was a nut inside of this panel that the last bottom fender bolt screwed into to secure the fender. As I loosened this bolt, the nut inside began to spin inside of this panel. I ended up cutting most of the bolt off because I can not get to the nut, nor can I seem to take this panel off easily, but do not know what to do when I try to put the fender back on.
HELP!!
HELP!!
Old 08-17-2002, 05:15 PM
Txbobcat Txbobcat is offline
If you are talking about the bottom bolt on the fender [the underneath bolt]. That nut is laying on a fork type extrusion which is welded to the inner body. Once you remove the fender you can remove the plate that the bolt is held in with. You can then get a new nut and weld onto that plate or a homemade plate to replace it with. I hope that helps and welcome aboard.
