Old 05-31-2005, 04:49 PM
Dave Schiffers's Avatar
Dave Schiffers Dave Schiffers is offline
No one in the street section has answered, so here goes.....
I'm about to mount my first flexplate and need to know if I'm to use loctite when torqueing to 95 ft.lbs?
Thanks, Dave
Thanks, Dave
Old 05-31-2005, 04:51 PM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
I (red) Loctite them, regardless of what the shop manual says.
Old 05-31-2005, 04:53 PM
MoJo's Avatar
MoJo MoJo is offline
Can't hurt
""Guitar groups are on the way out", "The Beatles have no
future in show business"
Decca Records rejection of The Beatles - 1962
Old 05-31-2005, 05:05 PM
Will "Loctite Blue 242" be addiquate here?
Thanks, Dave.
Old 05-31-2005, 05:12 PM
"Blue 242" is intended for smaller diameter fasteners- I think 1/4" and smaller.
Old 05-31-2005, 05:49 PM
Thanks "Pontiac Jack".....I'll get some tonight.
I'm trial fitting and am fighting with the thin metal shim, so I'm going to leave it off????
and then I can get only get 4 of the bolts in and the other 2 bind as I try to start the threads????Any Ideas whats up here???
Old 05-31-2005, 05:55 PM
I should add that the last 2 bolt holes are so close that I'm pretty sure I have it on correctly. Like I said, the threads almost catch but then I can't turn them with my fingers. Without the flexplate all 6 bolts go in easily with fingers.
How about a small hole file to slightly open up the holes?
Old 05-31-2005, 06:09 PM
ErikW's Avatar
ErikW ErikW is offline
You don't need to use loctite on them. Just torque them to spec. They will never back out.
1964 GTO
9.76 @ 137mph
2009 G8 GT
Old 05-31-2005, 06:11 PM
ErikW's Avatar
I am assuming your using a stock flexplate. The dimple on the flexplate aligns over top of the blind hole in the crank flange. Good luck.
1964 GTO
9.76 @ 137mph
2009 G8 GT
Old 05-31-2005, 06:21 PM
Cat SFI Flexplate that was was check for round before it left the suppliers shop...(Either Dude or Kaufman).
Old 06-01-2005, 08:05 AM
Scott65's Avatar
Scott65 Scott65 is offline
DO loktite them, they can and occasionally will back out. Also, anyone using the TCI flexplate should be aware that the coating they put on these will flake out from under the bolt heads and cause looseness. I found out the hard way on that one. I chipped it off on both sides and retightened to specs WITH red loktite.
'65 Tempest 467 3650# [email protected]
Old 06-02-2005, 03:18 PM
63RedCat's Avatar
63RedCat 63RedCat is offline
So thats what happened with my TCI flexplate! I agree Red Locktite. It makes a terrible sound when one or more of the bolts come loose!
Old 06-03-2005, 09:01 AM
engineer engineer is offline
locktite is not dependent on bolt diameter, blue works on bolts larger than 1/4.
Old 06-03-2005, 06:34 PM
Lerry: The Body Ventura..'s Avatar
Lerry: The Body Ventura.. Lerry: The Body Ventura.. is offline
Send a message via Yahoo to Lerry: The Body Ventura..
I've never used Locktite on flex to crank bolts. I never had one loosen either. They are all knuckle busting tight still when ever I disassemble..
Old 06-03-2005, 09:44 PM
Engineer- Yes, 242 Blue Loctite can be used on larger fasteners, in fact Loctite says 1/4"-3/4" diameter. Some of us, though, lean toward not using it on highly loaded places like crank flange bolts, since it's a "medium strength" threadlocker. Loctite's suggested applications of 242 include: Valve cover bolts, water pump bolts, and oil pan bolts.
Old 06-04-2005, 04:38 AM
edlord edlord is offline
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Scott65:
DO loktite them, they can and occasionally will back out. Also, anyone using the TCI flexplate should be aware that the coating they put on these will flake out from under the bolt heads and cause looseness. I found out the hard way on that one. I chipped it off on both sides and retightened to specs WITH red loktite. </div></BLOCKQUOTE>
Yes, i noticed the same when i had to retighten the bolts after using MOLYLUBE *so stupid* as prescribed in the ARP flywheel bolts manual...
Still hangin on tight with medium locktite and shoulder pulled out of the socket!!
