Old 04-12-2003, 05:00 PM
charles vance charles vance is offline
WHAT'S THE BEST INTAKE FOR A 455 EHEAD (87cc), 292 COMPCAM ( 244DUR.@ .050 )ENGINE. THE CAR IS A 79 TA THAT WEIGHTS 3200 W/O DRIVER, 400 TRANS, TIGHT 3000 STALL, AND A 3.42 REAR END.
Old 04-12-2003, 05:16 PM
SCOTT ESTERLE's Avatar
SCOTT ESTERLE SCOTT ESTERLE is offline
I like the Torker 2.
Old 04-12-2003, 06:49 PM
Big Injun's Avatar
Big Injun Big Injun is offline
With the "shaker" you'll need to use the Torker II.
Dave "Big Injun" Anderson
www.pontiacdragdays.com
www.geetotiger.com
[email protected]
www.4mypontiac.com
For GTO Celebration items click the tile coaster.
Old 04-12-2003, 07:14 PM
JEFF KING's Avatar
JEFF KING JEFF KING is offline
RPM is just as good, but it,s too tall for your ta,s shaker set up
"GTO? Good Times Only!!!" "Get Tools Out!!!"
"And he Asked, Who Owns This Car? With The Peace Sign, Mag Wheels, and the Four on the Floor??
Old 04-12-2003, 07:28 PM
mmm mmm is offline
I like my 455 / torker II. People say, "oh, but the rpm has .x % more low end torque", but with a 455, you already have more torque than the best steet traction can handle. I think the good fit under the hood is a big factor. Mine makes a definite "waaaaahhh" sound at about 4K rpm that I really like too- bonus+.
-Mike
I'm right at home in a filthy garage
Old 04-13-2003, 03:57 AM
I too like the T2. Used it on my 400, now my 428.
Shaker can be discreatly altered to use most carb/intake combos, including the RPM.
SECOND AMENDMENT: AMERICA'S ORIGINAL HOMELAND SECURITY.
I Misus Rash'!
Old 04-13-2003, 05:11 PM
Cliff R's Avatar
Cliff R Cliff R is offline
Last summer I dyno tested both on a 455 with unported E heads, Crower 60919 cam, and HS 1.65 rockers. The T-II made the highest peak numbers, both torque and hp. Nearly as I can remember the highest peak hp was 505 for the T-II and 494 for the RPM.....Cliff
Old 04-13-2003, 06:26 PM
RPM's Avatar
RPM RPM is offline
Send a message via Skype™ to RPM
What carb are you using?
67 GTO, 428, Q-Jet, TH400, 3.42, 12.50/107.5, whisper quiet
67 GTO, 400, Q-Jet, M20, 3.23, 14.02/98.7, loud & obnoxious
Old 04-14-2003, 07:47 AM
critter's Avatar
critter critter is offline
But, if you want to run the RPM, you can always use the Blocker High Velocity Induction System to make it fit.
http://www.blockersperformance.com
12.84 @ 106.89 with street radials.
12.63 @ 108.39 on drag radials.
