Old 03-30-2005, 09:24 PM
Held for Ransom's Avatar
I'm looking for build sheets (not PHS) on 1970 A-body cars built at the Fremont plant. Will also take info off the last line of your trim tag (build date and 2 strings of digits). Please PM me or E-mail me at [email protected] Thanks.
So long, farewell.
So long, farewell.
Old 03-30-2005, 10:02 PM
norton70 norton70 is offline
i have a 70 convert fremont car, what is it exactly you are looking for?
Old 03-31-2005, 04:19 AM
A copy of the build sheet, usually found on the top of the gas tank or hidden inside of the car. Or the last line of your trim tag (it will contain the build date (two digits and a letter), then 2 sets of 6 digits).
So long, farewell.
Old 03-31-2005, 10:15 AM
dont have the build sheet...will get the trim tag for u
Old 04-01-2005, 05:12 PM
dansgto1972 dansgto1972 is offline
O3A 370939 230222
Old 04-01-2005, 06:00 PM
Lenox273's Avatar
Lenox273 Lenox273 is offline
Location: California, KY. 30 miles south of Cincinatti, Ohio
I will check when I get home later. I think my 70 Lemans was built there. I have two build sheets on the car that I found. Fortunately one showed the info that was unreadable on the other. If it is, I will scan and email it to you.
Old 04-03-2005, 08:23 AM
gtoformula's Avatar
gtoformula gtoformula is offline
I recently pulled the gas tank from my 1970 and found the broadcast sheet there ... and in fairly good condition too. It did have some degradation around the edges, but may have what you need. Copy me back with the details and I'll check. I could make a copy and fax it to you. I don't always check this site, so you may want to send be a private message or send to [email protected]
Old 04-09-2005, 07:34 AM
4SLASH6's Avatar
4SLASH6 4SLASH6 is offline
here is mine mike, I have partial build sheet if there is some data you need ,let me know. 03D 391013 360157
70 GTO 400/[email protected]
Old 04-09-2005, 10:47 PM
dansgto1972 and 4SLASH6, PM's have been sent.
So long, farewell.
Old 04-10-2005, 01:15 PM
Judge Man Judge Man is offline
1970 GT-37 400 4speed: 05D 456929 800232
