Old 08-01-2002, 08:07 PM
mrw mrw is offline
Just found a set of 62 casting heads in a bone yard date code jan.17 69.What i would like to know is how the heads flow on a 400 block and what will the cr be on a .030 over 400 with .o49 thick head gasket.mrw
mrw mrw is offline
Old 08-01-2002, 08:42 PM
Brian Baker's Avatar
They flow well.
Assuming a combustion chamber volume of around 72cc and a 0 deck height, CR will be around 10.25:1.
Old 08-01-2002, 08:45 PM
78lemans 78lemans is offline
i think they are like 10.25:1 compression on a 400, i run them on my 455 with sunk top pistons, from what i understand all the d-ports run pretty close on the flow #'s but i'm sure someone will know alittle more about them than i know
i know they are good 4 barrel heads with 2.11 1.77's and have screwing studs and work will on my motor with a little home porting!
[ August 01, 2002, 08:52 PM: Message edited by: 78lemans ]
Old 08-01-2002, 11:53 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
My 62s cc'd 75cc and others have posted the same so use that in you calculations. They are a pretty decent flowing D port head.
Skip Fix
Old 08-05-2002, 07:59 PM
dwbrenner dwbrenner is offline
My 400 is bored 60 over and I have the 75cc 62 heads from a 428 I believe. the CR calced out to about 9.5 to 1. Runs great on 93 or 94 octane pump gas.
Old 08-05-2002, 10:20 PM
David Holmberg's Avatar
A +.060 400 with 75cc heads will be at least 10.2 comp.
[ August 05, 2002, 10:21 PM: Message edited by: David Holmberg ]
Old 08-05-2002, 10:58 PM
STripleduce's Avatar
STripleduce STripleduce is offline
"A +.060 400 with 75cc heads will be at least 10.2 comp."
Depending on deck height and gasket thickness it could be less.
