Old 12-31-2002, 10:01 PM
PINKY8301 PINKY8301 is offline
I HAVE A 71 GTO, CAN ANYBODY TELL ME IF IT HAS A 8.2 OR A 8.5 REAREND.
Old 01-01-2003, 10:20 AM
'70-'72 Pontiac A-bodys w/ 6cyl, 350, & 400 engines used 8.2 Pontiac 10 bolts with tapered bearing axles. The tapered bearing axles were alarge improvement but the 8.2 was still saddled with small pinion bearings & small ing gear to pinion gear area.
'70-72 Pontiac A-bodys factory equipped with 455 received Pontiac's version of the Chevy 12 bolt. stronger than the avg 12 bolt Chevelle but hampered by c-clip axle retention.
The 8.5 corporate A-body rearend was not used in a Pontiac A-body till '73 (new bodystyle-different rearend hsg geometry), though the 8.5 A-body was used by Buick & Olds in '71-72.
