Old 07-20-2005, 12:56 PM
71Firebird 71Firebird is offline
Well we still don't have an answer yet about my son's head gasket problem...shop said it would be magnafluxed on Monday and yesterday we stopped and they haven't even opened the hood yet
As a general rule, does the water pump get changed out with this?...seems to me like it would have been the water pump that failed causing the overheating and gasket to blow...
Reason I ask, I had a starter put in our Tercel at this same place and the work was fine, but my wife was charged $120 for the starter
I know enough to do that myself, but thought it was the timing belt...could have bought a starter for $60 at AutoZone and saved a bit...
So I'd rather go buy a water pump for $36 rather than have them get one and charge me $90 just for the part....
Thanks for the help guys ...
Steve
Time to put another Pontiac back on the road!
Old 07-20-2005, 11:36 PM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Like before, I'm only "stumbling around in the dark" about possible damage to his engine. But the shop's reference to magnafluxing puzzles me. Magnafluxing is done to find cracks in a piece of ferrous metal, like a block or crankshaft. The piece has to be stripped and cleaned. So, to magnaflux some piece of his engine, is assuming the shop will have done a couple hundred dollars worth of disassembly and cleaning already.
I'm sure this isn't any help to you- just sounds wierd to me.
