Old 05-28-2002, 12:03 PM
Nickv's Avatar
Nickv Nickv is offline
Crower #E29641. There is one on ebay that I bid on. Thinking of putting it in my 400.
"Everyone is entitled to be stupid sometimes, but you're abusing that privilege"
www.musclecargalore.com
[www.reverbnation.com/nikivee
1967 Pontiac GTO
1967 Pontiac Grand Prix
1972 Pontiac Lemans Sport Convertible
2015 Dodge Challenger Scat Pack 392, 6 speed
2021 Ford Explorer
Nickv's Avatar
1967 Pontiac GTO
2021 Ford Explorer
Old 06-01-2002, 10:57 AM
Nickv's Avatar
Well, I guess nothing.
1967 Pontiac GTO
2021 Ford Explorer
Old 06-01-2002, 02:17 PM
2FAST4U 2FAST4U is offline
I don't know- I looked through the Crower catalog and almost all their Pontiac cams start with a part number of #6...
Dont funk with the 455...
Old 06-01-2002, 03:21 PM
Goatman Goatman is offline
On Vacation
I would call Crower and ask him. It may be something that he did custom. At any rate, he'll definitely be able to tell you everything you want to know.
Old 06-01-2002, 05:02 PM
cpetrice cpetrice is offline
here is the camshaft....
part number 60355
COMPU-PRO /PERFORMANCE LEVEL 5 -Upper mid-range and top
end profile for added power above 7000 rpm.
RPM Power Range:5200 to 8000 plus.
84360
318FDP
110 °
.591"
.579"
324 °
318 °
389
455
280 °
274 °
cut and pasted from crower mag. this is the only pontiac cam made by crower on ebay at the present time. The rpm range is 5200 to 8k. so you would have to have a high revving engine for this cam to be useful. what is your setup???
Old 06-02-2002, 01:52 PM
bob8748 bob8748 is offline
5200 - 8K seems awefully high RPM range. Building mine for top end and dont see it goin much over 6000. I too am interested in your set up. Dont see the 400 spinning that high.
So let me get this straight:
Your Honda has 1.6 liters and my bottle of Mountain Dew has 2?
Old 06-02-2002, 02:00 PM
Nickv's Avatar
Cpertice, that cam is not the one I was looking at.
1967 Pontiac GTO
2021 Ford Explorer
Old 06-02-2002, 02:46 PM
okay,that was the only one on ebay for pontiac,unless you were eyeballing the sbc one.....
Old 06-02-2002, 03:04 PM
Nickv's Avatar
Ok, I think I found the specs.
Specs are 239/247 @ .050" with .500/.522" lift using 1.5 rockers.110 LSA
1967 Pontiac GTO
2021 Ford Explorer
Old 06-02-2002, 03:36 PM
what heads,etc are you using? on pontiacwarriors.com,on a desktop dyno,they are using 6x heads,with a cam similiar to that one,Duration: 240 Intake / 246 Exhaust (@ 0.050)
Lift: 507 Intake / 510 Exhaust
and getting Peak HP: 363 HP @ 5000 RPM
Peak Torque: 406 lb./ft @ 4000 RPM
THIS IS JUST A DESKTOP DYNO!! (that'll keep the naysayers happy nick)
Old 06-02-2002, 04:01 PM
Nickv's Avatar
72cc Eheads, performer rpm intake, 750dp holley, 1.65 Crane roller rockers, trw pistons with .990 bbc pins, stock rods, polished, shotpeened with arp bolts, 2 bolt mains, studded.
[ June 02, 2002, 04:02 PM: Message edited by: Nickv ]
1967 Pontiac GTO
2021 Ford Explorer
Old 06-02-2002, 04:31 PM
damn nick,I don't know. there is no engine in the dyno sims with a cam that spec,a smaller cam,here is those stats.
Edelbrock Performer RPM Cam: (Ram Air IV cam)
Summary: Duration: 231 Intake / 240 Exhaust (@ 0.050)
Lift: 470 Intake / 470 Exhaust
LSA: 113.5 degrees
Overlap: 87 degrees
Peak HP: 416 HP @ 6000 RPM
Peak Torque: 396 lb./ft @ 5000 RPM
Old 06-02-2002, 04:32 PM
this is with 1.5 rockers,I might add.
Old 06-02-2002, 08:19 PM
Nickv's Avatar
This cam may be an older discontinued crower cam.
I was thinking of putting it in my 400. I may still do that, since I won the ebay bid. [img]smile.gif[/img]
It seems like a radical cam to me, along the lines of say the CC292 cam.
1967 Pontiac GTO
2021 Ford Explorer
Old 06-03-2002, 12:33 AM
May be a little radical...but hey you can always use Rhodes Lifters to tame things a bit.
Old 06-03-2002, 01:56 PM
Tim Swain Tim Swain is offline
This past weekend I changed to a smaller solid cam. I get better quarter times with single pattern cams, with under 40 NET duration and under 500 NET lift.
Now this is a street car on passenger tires.
Try the cam if you don't like it you can always change it. I like changing cams, I've had 4 cams in my 66 goat. I can't wait to try this one out at the track.
Old 06-04-2002, 06:19 PM
PROBRD PROBRD is offline
Since you have e-heads it sounds like a good cam for a street car. If you had unported d-heads I would say it is probably too big. I would put it in. It should run pretty well. [img]smile.gif[/img]
1/8th mile 6.52 @ 104
1/4 mile 10.43 @ 128
Old 06-05-2002, 07:55 PM
Nickv's Avatar
I wonder how it will perform with my 3:55 rear and stock converter? Hmmm... I guess I'll try it and see.
1967 Pontiac GTO
2021 Ford Explorer
Old 06-13-2002, 07:15 PM
Nickv's Avatar
Well I recieved the cam today along with a set of new crane lifters.
Here are the specs:
Lobe Separation 110
Intake Centerline 106
Advertised Camshaft Specs:
Intake: 304 Lift .500
Exhaust: 312 Lift .522
Duration @ .050
Intake 239
Exhaust 247
Lobe Lift
Intake: .333
Exhauset: .348
Looks like a custom grind from Crower Cams.
I'm thinking of installing this in place of my Crane HMV272 cam in my 406.
406ci,72cc Eheads ported, performer rpm intake, 750dp holley, 1.65 Crane roller rockers, trw pistons with .990 bbc pins, stock rods, polished, shotpeened with arp bolts, 2 bolt mains, studded.
TH400 with 3:23 stock converter.
What do ya think? Good cam? what can I expect?
[ June 13, 2002, 07:15 PM: Message edited by: Nickv ]
1967 Pontiac GTO
2021 Ford Explorer
