Hey guys:
Finally got my headers thanks to some help from Scott @ summit. (THANKS SCOTT) Anyway, I thought I read on here somewhere that a few of the diehards suggested that I take the headers to a machine shop and have the tube "lips" ground down smooth before installing with the gasket. Is that what I should do, or is it a waste of time? Thanks Chris
Save it.....you never know! 1967 Firebird 455 Th400 |
Hey guys:
that would almost guarantee all 8 cyl leaking. the weld rings around each port are what bites into the gasket and seals it.
![]() My Daddy bought me a car but all I got was this old Pontiac.
Chris,
Just install the headers.
1964 Tempest Coupe LS3/4L70E/3.42 1964 Le Mans Convertible 421 HO/TH350/3.08 2002 WS6 Convertible LS1/4L60E/3.23 1966 VW Type 2 Single Cab Pickup 140hp 2276 1956 VW Type 2 Panel Van 36hp 1200 1957 VW Type 1 Beetle 180hp 2276 |
Thanks for the advice guys: What should those bolts be torqued @ ???
Also, the ones I ordered are black. Do you suggest removing the coating on them now and applying some good quality heat paint???? Or is it just a waste??? Thanks again! Chris
Chris,
I ask Hooker headers about the black paint and they told me it was there just to keep the headers from rusting in the box. I took my headers to a powder coating outfit and had them ceramic coated. I saw on several post that the ceramic coating can last a few years. |
good luck "torquing" your header bolts. we donthave chevys. you'll be lucky to have the wrench you need to get to the number 6 and 7 bolts. you pretty much wanna tighten them down as much as you can with whatever open end / ractchet/socket combo u use
71 grand prix SJ 4280# 462 new for 2008 - 8.7:1 , 98cc 6Xs 246/209, 342 12bolt , BW S475 turbo JGS 50mm WG 56mm BOV. 600hp the easy way! |
you can get smaller than stock 12 point header bolts from arp...they help...a little...
'74 formula 400, w/shaker (3 scoops) black deluxe interior, '70 406 balanced assembly, .30 trw slugs, moly rings, 4x heads 2.11/1.77 stainless valves, ra 4 cam, e-rpm intake, holley 750 vac. sec, msd hei, hooker headers w/ dual 3'' flowmaster 50 series ending at axle, t400 w/ GM6 convertor, transgo shift kit, b&m starshifter, 3.08 gears, centerlines, 265/50-15 bfg's rear and 235/60-15 front...yes im over cammed but it is still very fun... |
HEY FRANK 75:
Just curious...how much did they charge you to coat your headers at the shop????? How did they turn out??????????? Chris
i posted something abou thte smaller bolts in the exhaust forum. the 5/16ths ARP header bolts helped me out tremendously. those 2 almost impossible bolts turned cursing and yelling into patiently wrenchin 1/4 turn at a time with an 8mm stubby. ill WILL NEVER use the 3/8 heads again. altho the smaller head bolts seem to loosen up. when i yanked my motor 2 were missing. altho i never checked them to re-tighten them in the yr and a half i drove the car onthe street.
Chris,
I had alot of parts powder coated, but I believe it was $100 and they turned out great. Have not put them on yet as I am still waiting for my stroker crank. |
THANKS FRANK!
I can almost be certain that someone suggested grinding something down on the headers....does anyone know what it was??????????? Thanks for the help CHRIS
