Old 01-29-2005, 03:41 PM
sub4600 sub4600 is offline
I have a '69 GTO, all original, but notice that the front bumper is not fitting correctly in the middle. It lines up fine with the front fenders, but there is almost an inch gap at the center. The hood is correct fit back by the windsheild. Could someone have removed it at sometime and not put it back on correctly, or is there an easy adjustment I can do to bring just the center in? Any help would be appreciated. Thanks in advance.
Old 01-29-2005, 05:06 PM
68ragtop's Avatar
68ragtop 68ragtop is offline
If it has the endura bumber, it is probably bent in at the bottom. Pretty common problem. If the bumpers get tagged in the lower front they will open up at the hood, & usually not fit the fenders real good at the bottom near the valance. Just take a look at the sides, & see if the center follows the same plane.
There are many posts on this topic as well.
68ragtop
68 GTO 4-spd Convertible
78 S/E Trans am L78, WS6 Auto
78 S/E Trans am W72, WS6 Auto
79 10th aniv W72 Trans am
80 Indy pace car Trans am
89 Trans am GTA
Old 02-01-2005, 08:46 PM
Thanks, will check it out and the other posts.
