Old 01-26-2001, 03:36 PM
Engo's Avatar
Engo Engo is offline
Is this intake any good? Better or worse than a Performer?
Street/strip 1969 TA clone. Back halfed. 3300lbs. Twin turbo LSX 387cu. JW glide. Holley Dominator EFI. E85. Street driven.
https://www.facebook.com/photo.php?f...type=1&theater
Engo's Avatar
Old 01-26-2001, 04:14 PM
Will Will is offline
Worse. It would be okay for a stock engine, nothing more.
Old 01-26-2001, 05:48 PM
Black 65 GTO Black 65 GTO is offline
I have run a couple different intakes on my '65 389, factory '65 cast Iron, Performer RPM, and Edelbrock P4B. The current intake in use includes the Edelbrock P4B. I have noticed a substantial improvement in low end and mid range with this old P4B manifold over a Performer RPM, not to say that it's the "perfect" intake manifold but it works well for my application. If you are running a 389/400 using cast iron heads, with an shift RPM of no more than 5500,I would not hesitate to use this manifold, if you already have one as I did. I feel that even a mild street/strip 389/400 w/ stock D ports might be better off with a smaller intake since the Performer RPM has a large plenum and bigger runners compared to a Performer/P4B. If your buying a new intake, I would purchase the Performer. I would imagine that you would find comparable performance on the street between the Edelbrock Performer and the Edelbrock P4B.
[img]http://photos.msn.com/imageserver/image.aspx?Image=HcZNnT9kkUh7v3gGH5Km42rZ7vcme1lp* UaM!VDE1BG*vgDalH3kuL5h3zNqazZzIGM4Vs6rS1*M8m6jwq2 RRzGpoEcUD1hew3uV4awBUsyFSmp5gkgscnHcokRZl*b8MCsY3 sAhyRgDddNSylRh*Q$$[/IMG]
Old 01-27-2001, 02:12 PM
Half-Inch Stud's Avatar
All this...without the benefit of the Spreadbore carb.
Holley/P4B vs Q-Jet/Factory RamIII iron.
I like the Q-Jet/Iron to meet those street&strip goals.
Old 01-27-2001, 03:26 PM
Guy Mazza's Avatar
Guy Mazza Guy Mazza is offline
I run a P4B on my totally stock 350 w/600cfm Carter AFB. The engine is in my 64 LeMans daily driver (100 miles a day). This was a typical engine I put together w/ Stuff I had laying around. Its not a bad manifold for a near stock motor. The only real advantage to it is its lighter & has a square bore carb flange.
Old 01-27-2001, 10:52 PM
I guess there is a reason they don't make this manifold anymore!
Half Inch, someday I will probably try a Performer along with a Quadrajet. I sure liked the one in my old original '67 GTO!
